Need some help with oem g35 diff
Old Mar 29, 2009 | 10:10 AM
NAZ33's Avatar
NAZ33
Default Need some help with oem g35 diff
Hey Guys, anyone knows if the G35 06 c differential (lsd) is equal to 06 differential(no lsd) 350z?, because when i put on my Z, both rims had a play, so i dont know if the axles of the G35 are bigger than those ,or the differential fron the Z is shorter?.............help please!
Old Mar 29, 2009 | 11:59 AM
NAZ33's Avatar
NAZ33
Nobody???
Old Mar 29, 2009 | 06:03 PM
NAZ33's Avatar
NAZ33
Guys im really need your help, thanks
Old Mar 30, 2009 | 04:47 PM
NAZ33's Avatar
NAZ33
bump
Old Mar 30, 2009 | 04:55 PM
NAZ33's Avatar
NAZ33
bump
Old Mar 30, 2009 | 05:04 PM
NAZ33's Avatar
NAZ33
bump
Old Mar 30, 2009 | 07:26 PM
NAZ33's Avatar
NAZ33
bump!
Old Mar 30, 2009 | 07:31 PM
chrisaray's Avatar
chrisaray
Are you talking about a full pumpkin or just a diff change? I believe the axle stubbs are different between the LSD and non LSD. But, if you are swapping the entire pumpkin, you should have no problem.
Old Mar 30, 2009 | 08:07 PM
NAZ33's Avatar
NAZ33
thanks god!
Is the full pumpkin with axles came from g35 ........
there must be something different......., thanks
Old Mar 30, 2009 | 08:15 PM
chrisaray's Avatar
chrisaray
The G pumpkin will bolt right in to your Z. Use the stub axles that are already in the G pumkin and use the stock axles (half shafts) that are already on your Z. Remember that the inner CV joints are telescopic. They move in and out making the axle longer and shorter with suspension movement. You may have to extend the inner joints a little to make them mate up. I have a G pumpkin in my Z.
Old Mar 30, 2009 | 08:27 PM
NAZ33's Avatar
NAZ33
ok im going to try with the stock axles from my Z, and lets see waht happen, thanks for your help
Old Mar 31, 2009 | 03:08 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I have a z pumpkin in my g and no problems.
Old Mar 31, 2009 | 05:03 PM
NAZ33's Avatar
NAZ33
wuts up!, today i put the stock axles from Z with the G pumpkin, and still the problem, so i had to do, was put a washer on each end of the axles, and the problem gone...........
Old Apr 1, 2009 | 01:20 PM
NAZ33's Avatar
NAZ33
bump
350z82
Oct 1, 2015 06:25 PM
