Spark plug help????
Old Apr 6, 2009 | 04:58 AM
cedoulinou's Avatar
cedoulinou
Default Spark plug help????
Hi guys
It's time for me to change my Z's spark plugs. I would like to know if installing 1 step colder spark plugs on a NA Z will help to improve performance (a little bit .
What are the best spark plugs that I could install on my car???
thanks
Old Apr 6, 2009 | 05:30 AM
singh's Avatar
singh
_______________
oem
Old Apr 6, 2009 | 06:48 AM
huyrua's Avatar
huyrua
Old Apr 6, 2009 | 07:41 AM
cedoulinou's Avatar
cedoulinou
which brand and model should I buy
Old Apr 8, 2009 | 06:25 PM
JROCK 2003's Avatar
JROCK 2003
I used NGK. Not gonna really get a performance gain from different brands from what I understand..... Have fun with the install though, its a blast. Haha..
Old Apr 9, 2009 | 05:51 AM
cedoulinou's Avatar
cedoulinou
Should I use NGK iridium LFR5AIX-11 or LFR6AIX-11 (think these one are for forced induction -» one step colder)???
Old Apr 9, 2009 | 09:23 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Apr 9, 2009 | 03:40 PM
Gingervitis526's Avatar
Gingervitis526
oem is the 5 series, i'd imagine if you went with the 6 you would fowl them up in no time
Old Apr 9, 2009 | 03:59 PM
maximariceboi's Avatar
maximariceboi
OEM. 1 step colder is for boost!
Old Apr 10, 2009 | 05:35 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
On a stock engine going to a colder plug will actually hurt performance if anything because it's more likely to foul a plug. The colder heat ranges are used for F/I applications or nitrous to prevent detonation. There is no performance gain from a colder plug, you want to run as hot of a plug as you can without detonation.
Use the OEM heat range, go with NGK.
Old Apr 13, 2009 | 07:20 AM
cedoulinou's Avatar
cedoulinou
thanks guys
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
