Oil pan bolt torque specs?
Old Apr 16, 2009 | 10:21 AM
moog's Avatar
moog
Default Oil pan bolt torque specs?
VQ35DE - Can't seem to find the figure anywhere...help is appreciated.
Old Apr 16, 2009 | 11:57 AM
coachk's Avatar
coachk
I read 63 in/lbs....
Old Apr 17, 2009 | 12:56 PM
AMF's Avatar
AMF
Not to go off topic completly but, I was told my oil leak I have had for a while is from my oil pan seal. The shop quoted me about $1,000 and said they have to pull the motor. This immediatly sounded suspect, and now I am convinced they don't know whats going on if you guys are just dropping the pan from the bottom. or an I mistaken???
Old Apr 17, 2009 | 01:08 PM
moog's Avatar
moog
Well there's an upper and lower oil pan. It can leak from a lot of different places. have them show you exactly where it's leaking on a parts diagram.
Old Apr 17, 2009 | 04:02 PM
coachk's Avatar
coachk
Which pan were you asking tq specs for, upper or lower??
Old Apr 17, 2009 | 04:13 PM
moog's Avatar
moog
I was asking for lower. I just took off an ARC oil pan and need to reinstall my stock one.
Old Apr 18, 2009 | 07:50 AM
coachk's Avatar
coachk
I just called Nissan and the guy said that the tq spec for the lower oil pan is 9in/lbs.... I can't remember for sure what they are when I did mine. Sorry
Old Apr 18, 2009 | 10:50 AM
terrasmak's Avatar
ARC oil pan , what are you doing with it???
Old Apr 19, 2009 | 04:44 PM
moog's Avatar
moog
Sold it to a local member.
Old Apr 19, 2009 | 05:06 PM
moog's Avatar
moog
Finally found it 78in/lb
Old Apr 19, 2009 | 05:41 PM
coachk's Avatar
coachk
Sorry about the bad info I gave you.....F'in Nissan derelicts. I feel like going up to Nissan tomorrow and smacking the guy who told me 9
Old Apr 19, 2009 | 08:24 PM
QuadCam's Avatar
QuadCam
just about all the M6 bolts (10mm head) have an 80 in-lb torque rating on this engine.
Old Apr 21, 2009 | 12:28 PM
moog's Avatar
moog
missing 3 bolts, can I use any M6 bolts the same length w/o issue?
Old Apr 21, 2009 | 01:18 PM
QuadCam's Avatar
QuadCam
yes.....but you may want to add a washer or lock washer uner the bolt head. also, I have found that advance auto parts has similar bolts to the factory bolts....bolts with a nice flange molded into it. they are even gold in color, like the stockers.
burglapfd
Dec 6, 2020 01:04 PM
