Engine Noise
Old May 18, 2009 | 05:33 AM
GA_VQ's Avatar
GA_VQ
Could be throw out bearing on clutch. When you get going faster you can't hear it.
Old May 18, 2009 | 07:57 AM
06Track's Avatar
06Track
You need to take a close look at the crankshaft and see if the bearing did
any damage..also check and make sure the rod is not damaged or discolored
(blueish color on cap). What kind of oil pressure was your car running at idle
and cruise after being warmed up?
Old May 18, 2009 | 05:20 PM
GA_VQ's Avatar
GA_VQ
I already sanded the crankshaft down. It was pretty messed up! Started at 240 grit, then 400, 800 and finaly 1000. Took about 2 hours. Doesn't look quite like the others. Still has some spots on it but I would say it's about 95% flawless.
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
