balanced and blueprinted???
Old May 6, 2009 | 05:25 PM
gmic350z's Avatar
gmic350z
Default balanced and blueprinted???
anyone know what balanced and blueprinted is?i saw grand national and it says nothing done to car but getting the motor balanced and blueprinted and hes got 400 horse on the dyno from doing that alone.??
Old May 6, 2009 | 06:01 PM
crash1555's Avatar
crash1555
while im no expert...engine components are made to very small tolerances straight out of the factory.
so i doubt re balancing even a very old motor would net any gains.
Old May 6, 2009 | 06:07 PM
gmic350z's Avatar
gmic350z
ive seen other cars in magazines or whatever it was in the past and they all got some good gains from this.
Old May 6, 2009 | 06:29 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
http://www.rpmrons.com/Balance.html
Old May 6, 2009 | 08:37 PM
jZ08's Avatar
jZ08
Default Color me highly skeptical
Balance & blueprinting was a standard thing to do to Detroit V-8's to compensate for 1950's manufacturing technologies. I call caca de toro that my smooth VQ35HR engine has 64 hp just waiting to be unlocked by B&B on it.
It didn't help the crappy old detroit iron "in the good old days" that much and these engines are a technical master piece compared to them.
Old May 6, 2009 | 11:42 PM
bbs350z's Avatar
bbs350z
^^wtf does that say?
Old May 7, 2009 | 02:38 AM
gmic350z's Avatar
gmic350z
caca de what?
Old May 7, 2009 | 06:34 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
The term refers to building the engine, balanced and blueprinted means that the engine has been balanced before assembly and that it was planned out from the start and not thrown together. There is no power gain from this term, it's merely a stage in building an engine.
Old May 7, 2009 | 09:03 AM
6.2Ldream's Avatar
6.2Ldream
In addition to everything being balanced, most builders will check the piston to wall, bearing to crank and other clearances as well to make sure they are all the same (or very close, like w/in .001"). To add to this, when compared to a non B&B engine, it will run smoother and should be dead even across all cylinders. Not all builders B&B engines because it is additional time, but it is def worth the additional time when trying to squeek the last bit of power out of a setup.
Old May 7, 2009 | 12:00 PM
bryan@Z1's Avatar
bryan@Z1
Anyone who fails to check piston to wall, ring end gap, and bearing clearances when building a motor has no business building a motor in the first place. Those are basic fundmentals of a rebuild.
Old May 7, 2009 | 12:53 PM
evil_tt's Avatar
evil_tt
^lol +1
Old May 7, 2009 | 01:57 PM
Zenica's Avatar
Zenica
+1 and then some...
Old May 7, 2009 | 02:57 PM
350junkie's Avatar
350junkie
caca de what?
bullsh**
Old May 7, 2009 | 06:53 PM
jZ08's Avatar
jZ08
Originally Posted by 350junkie
bullsh**
'xactly!
Old May 8, 2009 | 03:50 AM
Zenica's Avatar
Zenica
Oh, as in what a 2 year old might say..."caca doo doo"?
Because we're too bashful to say BS or Bullsh!t or Bullsh** more directly.
Old May 11, 2009 | 09:14 AM
6.2Ldream's Avatar
6.2Ldream
You are correct, however a lot of people that "build" engines don't do those things so I figured it could not hurt to put it out there.
DarkCreep
Oct 17, 2015 11:50 PM
Paul.
Oct 16, 2015 07:34 PM
N74DV
May 3, 2005 11:02 AM
Gromadusi
Feb 18, 2003 09:22 PM
