Grinding sounds near front of engine!!
Old May 8, 2009 | 02:34 PM
04SILVERBULLET's Avatar
04SILVERBULLET
Default Grinding sounds near front of engine!!
Its like theres gravel on the belts or something, what could it be??? Its a gravel/grinding sound right where all the belts are. Did lil research could be the water pump. Is there anyway to check it without taking everything apart? or could it be something else?
Old May 8, 2009 | 04:01 PM
mthreat's Avatar
mthreat
Could it be the timing chain tensioner? If it isn't tensioning right, the chain is loose and makes all kinds of noise. I think this is very easy to inspect by taking off a small cover on the front of the engine, that allows you to peek in to see the tensioner.
Old May 9, 2009 | 08:36 PM
04SILVERBULLET
alright, ill give that a shot.
Old May 10, 2009 | 05:45 AM
DavesZ#3's Avatar
DavesZ#3
Bearing in one of the idler pullies?
Old May 10, 2009 | 09:34 AM
kramykram's Avatar
kramykram
+1
That's what it sounds like to me.
Old May 10, 2009 | 11:49 AM
kensin0429's Avatar
kensin0429
go check your hub bearings might be cracked
liqalu04
Jan 2, 2022 12:58 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
samansharif
Sep 25, 2015 12:31 PM
