**Clutch Pedal Issue**
Old Jul 29, 2009 | 06:25 PM
M3ANMACHINE's Avatar
M3ANMACHINE
Default **Clutch Pedal Issue**
Well i'm about to hit 60k miles on my '05, and have recently noticed the clutch slipping quite a bit, so obviously it's time to change the thing. I'll be going with something along the lines of the JWT clutch & Lightweight Flywheel Combo, because my Z is a DD. (Recommendations for any other good combos are also welcome)
The problem I am facing is as follows: For quite some time, my clutch pedal has always felt pretty odd, it seems pretty heavy and disengages & engages only about less than 1 inch before my foot is off of the clutch pedal, and also feels like it has ZERO free play before it moves... Everyone who drives it tells me they think somethings wrong and I just can't figure out what it is. Anyone else experience this?
My question is, do you think that the problem with the pedal is only happening due to the fact that the clutch is just about finished, or is something else (such as the slave or master cylinder) causing these issues?
or Do I just have to wait and see if the pedal feel changes after installing a new clutch/flywheel?
I'm pretty stumped here, as I don't have a huge amount of mechanical experience at the moment, so any help is appreciated!
Thanks!!
Old Jul 29, 2009 | 07:40 PM
freedonutss's Avatar
freedonutss
1 inch before you depress it? Thats pretty low for a Z. Out of the Zs ive driven the engage point is pretty far up.
Old Jul 29, 2009 | 08:05 PM
knils's Avatar
knils
mine seems to be the same.. very quick to engage, and very harsh once it does. 03/60k
Old Jul 29, 2009 | 08:09 PM
M3ANMACHINE
sorry, i mean less than 1 inch before my foot is completely off the pedal.
it also obviously disengages at the same point...
Old Jul 29, 2009 | 08:51 PM
freedonutss
Ohh ok sorry I misunderstood you. I think its normal for Zs engagement points to be pretty high. I had to drive my cousins burnt clutch G35 to forged and it almost feels the same as your describing. I think you just have a worn clutch. My Z has around 61k miles but its not worn yet so I cant help you there. Good luck.
Old Jul 29, 2009 | 11:08 PM
M3ANMACHINE
Thanks for the input.
Anyone know if the problem should be resolved by replacing the clutch and flywheel?
Old Jul 30, 2009 | 11:43 AM
M3ANMACHINE
Bump...
Old Jul 31, 2009 | 09:46 AM
Zoom750's Avatar
Zoom750
IIRC, it has been reported by some that the engagement point have been shifted after a clutch replacement. I would PM Sharif or Adam for their opinion. G/L.
Old Aug 1, 2009 | 02:16 PM
M3ANMACHINE
^^ Thanks, will do.
Anyone else have any ideas?
Old Aug 1, 2009 | 05:14 PM
madpanda's Avatar
madpanda
The JWT clutch isn't bad, but I recommend you going another route on the flywheel.
Go with anything other than JWT with the flywheel, the extreme rattle is just overkill.
Almost all of the other aftermarket flywheels do not have excessive rattle.
As far as your clutch point, you should ask Ryan if he ever put in a clutch spacer, that's the only thing I could think of, or go take it to a trustworthy mechanic to get it diagnosed.
Old Aug 1, 2009 | 05:21 PM
M3ANMACHINE
Any recommendations on flywheels?
Ryan didn't touch the clutch, all I can remember is that we did change the engagement point once, but we tried to do it closer to the floor... It worked for a while but kept moving back up.
I just noticed today that it feels semi-normal when the car isn't warmed up, but once it warms up it gets really stiff!
I'll definitely have them check it when I get the new clutch.
Thanks
Old Aug 1, 2009 | 06:04 PM
ALO8's Avatar
ALO8
is ur clutch sticking?
like the one described in here?
https://my350z.com/forum/texas/33899...-sticking.html
Old Aug 1, 2009 | 07:21 PM
terrasmak's Avatar
If its slipping , the clutch is bad . Its that simple, and yes the JWT flywheel is just fine on the street. If you don't want any extra noise , ket the flywheel stock .
Old Aug 2, 2009 | 11:29 AM
M3ANMACHINE
I already addressed that issue, but my question and problem is stated above.
I just wanted to know if the problem would resolve itself after a new clutch/flywheel.
Thanks
No sir
Old Aug 4, 2009 | 02:07 PM
madpanda's Avatar
madpanda
You probably won't know what it is until someone that knows what their actually doing gets down there. As far as flywheel, I heard great things for the Nismo and Exedy flywheels. G/L
Old Aug 5, 2009 | 11:04 AM
M3ANMACHINE
Thanks.
I'll def. have it looked at when I get the clutch/flywheel replaced!
Old Aug 6, 2009 | 08:30 PM
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
well i bought a new 350z and when after about a month of driving it the clutch pedal started to clunk and feel like it was getting cought on something so i looked at the actually pedal when i got home and the bolts that hold the pedal to the firewall were loose tightend them up and it feels like i have a new clutch now.
just throwing that out there.
Old Aug 7, 2009 | 03:08 PM
bdahern's Avatar
bdahern
I'm having this problem - 2006 with 47K miles - happens after hard driving or on hot/humid days. Has anyone discovered what the source is? The thread suggests about 5 things. Coincidentally my car wouldn't do it at the dealership today for the tech - first day under 80 and not humid of course.
Old Aug 7, 2009 | 03:30 PM
M3ANMACHINE
You should probably post your question up in that thread...
QuintonC
Interior
Sep 9, 2015 12:10 PM
