350z auto to 6speed
Old Jul 31, 2009 | 08:05 AM
GT-Z's Avatar
GT-Z
Default 350z auto to 6speed
I bought a 6 speed trans, does anyone know a web page or info
on how to install the clutch pedal and all the nec. stuff to install it.
i heard from some people u have to change the rearend.... need info asap
thanks!!
Old Jul 31, 2009 | 02:40 PM
terrasmak's Avatar
you also need an ECU and a bunch of other parts, have fun.
Old Aug 1, 2009 | 06:39 PM
damn_rookie's Avatar
damn_rookie
Good luck
Old Aug 1, 2009 | 06:43 PM
chefsz's Avatar
chefsz
Wow..
This cannot be a real post, I would hope you do more research before buying a 6spd trans with a though of conversion. There is a reason why almost no one has done it.
Old Aug 3, 2009 | 05:59 AM
GT-Z's Avatar
GT-Z
In progress will put pics up soon!
Old Aug 3, 2009 | 06:42 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I believe GTM has done this, you might wanna give them a call.
Old Aug 4, 2009 | 08:49 AM
JTinFL's Avatar
JTinFL
You will need a lot of parts off the 6 speed. It can be done. Good luck!
Old Aug 4, 2009 | 09:27 AM
Boogshag's Avatar
Boogshag
wow, what a job. it would probably be much easier to buy a manual 350z and sell yours, but i wish you the best of luck
Old Aug 4, 2009 | 10:05 AM
GMZ's Avatar
GMZ
This^^^ flywheel, clutch, clutch cable/master cylinder, bearings, ecu, is the driveshaft the same? Your pumpkin is of a different ratio than a stock 6MT. Even the trim pieces around the shifter are different.
Thats what I did.
Old Aug 12, 2009 | 06:52 AM
GT-Z's Avatar
GT-Z
Ya im sticking wth the auto now......
Old Aug 12, 2009 | 08:26 AM
Boogshag's Avatar
Boogshag
good call. it probably wouldnt be worth all the time and money for the conversion
Old Aug 13, 2009 | 06:02 AM
GT-Z's Avatar
GT-Z
Il stick with the auto, then when it goes out, il make the conversion i guess..... But dont have time for an all out project.....
Old Aug 13, 2009 | 07:49 PM
gregom's Avatar
gregom
different drive shaft I think is required... different ECU... yeah... lots of crap. I researched this myself but I don't think its worth the effort unless your a pretty serious mechanic and are willing to have no Z to drive for awhile...
But hey if you ever do decide to do it, and do it successfully... be sure to take lots of pics and write a how-to, and you'll be a god on the forum. lol
Old Aug 13, 2009 | 08:24 PM
jeffie7's Avatar
jeffie7
Why don't you just sell it to Alberto, he could always use a backup tranny.
Best way to install a 6 speed into an auto Z is.
go to www.cars.com list your car for sale, when its sold, take that money and put it towards a 350Z with a 6 speed.
Done!
Old Aug 15, 2009 | 11:23 PM
rocks's Avatar
rocks
You could get all the parts out of a junkyard and it probably wouldn't cost over 1500$ if you looked around for awhile. 99% of japanese cars already have the holes marked or drilled for the slave cylinder and clutch pedal mounting. BTW ecu out of a junkyard is about 150-400$... I don't know why people think it would be so hard lol.
Old Aug 16, 2009 | 05:41 AM
jeffie7's Avatar
jeffie7
If you have the tools and the know how to do it yourself its not that bad but for most people who want to do it, they want it done for them so that 1500 for parts turns into 2500-3000
Zs are getting lower and lower in price, making even less sense on spending 2500-3000 for something that can be bought stock.
Don't forget the new tranny, I built a turbo civic and it took 3 trannys to get one that didn't grind. I even bought a TH350 tranny for another project that I thankfully took apart before installing only to find out it was trashed. (TH350 came from pick and pull yard with warranty) I never did get back the lost time......
lots of factors play into it, easiest way is to sell the car, and buy one with a 6 speed. figure the car is worth 12-15K sell it and buy another one in the same price range, hopefully breaking even.
If the OP has the means to do it on his own and has a good place to get parts under warranty (have them checked out first!) then theres no reason not to.
However most people who post on here that want this swap can't find the spark plug wires in a 350z
Old Aug 16, 2009 | 06:06 AM
SirSpeedyZ's Avatar
SirSpeedyZ
jeez, I say sell and buy a 6MT save yourself a lot of trouble
Justin100
Nov 29, 2015 03:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
codek
Sep 28, 2015 03:03 AM
jlc280z
Sep 24, 2015 08:43 AM
hardkicks
Sep 20, 2015 12:28 PM
