06 revup motor in a 03 z will it work?
Old Aug 19, 2009 | 07:19 PM
trace1's Avatar
trace1
Default 06 revup motor in a 03 z will it work?
Ok long story short I blew my motor and bought a new long block that I thought was 03 to 04 but it turned out to be a revup motor. Does anyone know if this motor will work in my 2003? I know we have to block off the secondary cam sensor wholes but will the motor run without the vvl?
Any help would be great. I know alot of you are going to say just buy am 03-04 motor but I got the motor for 750 bucks and really want to try and make it work.
Old Aug 19, 2009 | 08:10 PM
gabe3d's Avatar
gabe3d
yes you can. you will need to plug the exhaust side vtc.
Old Aug 21, 2009 | 01:25 PM
mtm864's Avatar
mtm864
how would you go about plugging the exhaust side?
Old Aug 21, 2009 | 03:27 PM
Zolid's Avatar
Zolid
Did the engine come with a full wire harness and ECU?
Old Aug 24, 2009 | 07:36 AM
trace1's Avatar
trace1
It only came with the long block.
Motor is up and running I will be getting it tuned on the 31st using osiris uprev with megan long tube headers 5/16 md plenum spacer arc intake and hks high power exhaust.
I will post numbers when I get them.
Old Aug 25, 2009 | 12:35 PM
bbs350z's Avatar
bbs350z
so did you plug the holes or did you swap heads? info sir
Old Aug 25, 2009 | 01:23 PM
YoungBB's Avatar
YoungBB
Old Aug 30, 2009 | 12:50 PM
trace1's Avatar
trace1
we plugged the holes in the revup head. and it runs perfect im getting it tuned tomorrow.
_bit
Oct 2, 2015 07:49 AM
