Lsx 03 350z
Old Sep 21, 2009 | 04:57 AM
jksstar's Avatar
jksstar
Stock GTO motor mounts :mrgreen:
the TH350 fits good and I'm able to use my stock trans crossmember also
Old Sep 28, 2009 | 04:19 AM
jksstar's Avatar
jksstar
Originally Posted by TransAm6383
Stay far away from Hinson!!! Ive heard so much bad **** from him on the v8rx7 boards!
I'm not using their kit
Old Sep 28, 2009 | 04:23 AM
jksstar's Avatar
jksstar
got most of the hard part done, mounts are all done and going to try and get the oil pan done this coming week. Did some test fits to make sure everything was going to clear
stock fans and rad.
biggest thing was making sure the hood would shut all the way, it does
Old Sep 28, 2009 | 05:58 AM
chris'smax's Avatar
chris'smax
I have been interested in doing this, but was really wanting to use the swap kit from hinson. What is the deal with them?? What is the reason for the negativity against them?
GT-Z's Avatar
GT-Z
Lookin good man. keep us up to date!!
Old Sep 28, 2009 | 06:34 AM
jksstar's Avatar
jksstar
I was going to use them, but after talking with them afew times I knew I had to do something else. They just have bad customer service imo.
If you are looking at a kit maybe try SIKKY http://www.ls1tech.com/forums/conver...40sx-350z.html
So far I have about $1,200 in this swap (motor and all) Thats less then any swap kit and I have not used a welder yet. When its all done I don't see me having more then $2,700 in it (after cam and tune). Its just taking time to get everything worked out.
Old Sep 28, 2009 | 06:36 AM
jksstar's Avatar
jksstar
Thanks
I'm trying to keep this updated
Old Sep 28, 2009 | 07:43 AM
chris'smax's Avatar
chris'smax
you were able to fab your own mounting brackets?
Old Sep 28, 2009 | 08:02 AM
jksstar's Avatar
jksstar
I used stock GTO motor mounts and just made a small bracket for the drivers side
where the red is on the crossmember is the stock motor mount bolt hole.
I'll get some pics of the bracket and you can see above on the pass. side it lines right up
Old Sep 28, 2009 | 09:53 AM
Havok_RLS2's Avatar
Havok_RLS2
JKsstar,
While I think you're efforts are awsome I'm a little consern about your mounting methods. From some the to photos you've posted the motor doesn't appear to be mounted center-line of the car. The motor appears to be sitting too far the right (pass side) and rear **** angled to the right (pass side) as well.
If I'm correct you're going to run into some major problems later when it comes time to do the drive shaft. I could be wrong though.
Old Sep 28, 2009 | 10:31 AM
jksstar's Avatar
jksstar
Originally Posted by Havok_RLS2
JKsstar,
The pics were took before the drivers side was bolted in so it may have been alittle off (sitting at a angle). It would move very easy with the mount just sitting on the cross member.
Also you are right, it does sit to the pass side more but that was the only way I could get it to line up. That was my biggest worry on doing this swap, I have double checked and I'm 99.9% sure my driveshaft will be straight.
Old Sep 28, 2009 | 02:07 PM
vthao's Avatar
vthao
Good work!
Old Sep 28, 2009 | 02:12 PM
Jeff92se's Avatar
Jeff92se
How are you resolving getting the engine to run with the chevy ecu and the Nissan guages/ bcm? Thanks
Old Sep 28, 2009 | 04:08 PM
Coffeemaster's Avatar
Coffeemaster
Might want to check http://fueledracing.com/
They make a swap kit and aren't garbage like Hinson.
Old Sep 28, 2009 | 05:56 PM
HeadGames's Avatar
HeadGames
is it me...or is there A LOT more room in there with the LS then the VQ?
Old Sep 30, 2009 | 07:26 AM
jksstar's Avatar
jksstar
everything I need on the car works without the ECU (not sure about the abs but don't need to have it) and I'm planing on running aftermarket gauges.
Old Sep 30, 2009 | 07:36 AM
Ztouring04's Avatar
Ztouring04
in for updates
Old Sep 30, 2009 | 01:33 PM
  #38
PlatinumSR20's Avatar
PlatinumSR20
Looking good! Can't wait to here it run.
Old Sep 30, 2009 | 04:01 PM
  #39
Havok_RLS2's Avatar
Havok_RLS2
I'm running both ecu's in my car. The GM PCM will be in total control of all engine function and tuning and the Nissan ECU will control all can functions and guages. One only guage I might have to cutomize is the tach because it receives it's signal from the Nissan injectors which is then routed through the ECU and then to the CAN system. The Nissan wont accept the GM signal but I have a plan in the works to remedy this situation.
Pulling out the Nissan CAN system would be too much of a PITA the EMC's BCM functions have too much control over the car to just simply remove. I mean things line Wipers, windows, horn, gauges, door locks, AC and heater, trunk latch, traction control, etc and all controlled through the CAN bus and nissan ECU. Get my point?
Old Oct 1, 2009 | 04:07 AM
  #40
jksstar's Avatar
jksstar
I have the Nissan ECU out of the car and wipers, horn, lights, door locks all that works, gas gauge and so on. I don't think the heater works but we have short winters where I live. Like I said everything I need works without it, now if I ever put a/c back on the car I will put the Nissan ECU back in.
Have you started your swap yet? Did you get a kit? Would like to see how you mounted evertything. Not alot of info out for this swap in 350s.
