Lsx 03 350z
Old Jan 3, 2011 | 01:15 PM
  #181
Quamen's Avatar
Quamen
Originally Posted by mw9
Can you help me with understanding the wiring on the throttle body. I have found the wiring diagrams on the the z's harness and the LS2's harness. It seems that they are pretty close. Thanks for any info.
Absolutely!
Take the stock Z throttle cable wires, follow them all the way back to the ECU harness, tear them completely out of the main connector! Purchase cable operated throttle body and complete project.
Old Jan 3, 2011 | 01:22 PM
  #182
mw9's Avatar
mw9
Originally Posted by Quamen
Absolutely!
Thank you sir, so you are getting rind of the drive by wire system and going back to a cable. I see.
Old Jan 3, 2011 | 03:50 PM
  #183
Quamen's Avatar
Quamen
Yup. Going to cable is ten times easier than integrating the drive by wire. Luckily there are quite a few cable kits out there for LS swaps. I purchased the Lokar kit which is Teflon lined and SS braided outside. Includes all hardware.
Old Jan 4, 2011 | 05:33 AM
  #184
jksstar's Avatar
jksstar
Here are some pictures of the throttle cable. I have to bend the firewall a bit to get it straight. I drilled the firewall pass through with the dash in so it was a bit hard to get it as perfect as I wanted. It still feels smooth though and works great!
You can see in the first picture that I should have made the piece of "u-channel" I welded on a bit longer and moved the mounting point for the cable up a bit for better cable alignment. The second picture is showing how I cut some of the pedal stop out to increase my pedal travel. Now that I have stripped my interior I have to add some length back to the stop but oh well.
Thanks
Old Jan 4, 2011 | 06:41 AM
  #185
mw9's Avatar
mw9
Absolutely!
How does the ecu act without this signal. Looks like no problem adding the cable, not sure how the ecu will act when it does not see this signal.
Old Jan 4, 2011 | 08:41 AM
  #186
Quamen's Avatar
Quamen
Which ECU? The stock Z? If so, who cares what the stock Z ECU thinks. It controls nothing on the car anymore other than the fuel pump which I recommend rewiring so you can't have fuel cut.
Everything in my car works flawless and I seriously removed about 30 wires from the main harness connector, an I mean removed as in yanked them completely out.
Old Jan 4, 2011 | 09:04 AM
  #187
mw9's Avatar
mw9
Ok, thanks. Wasn't sure if it would put the car in limp mode or something. I will start looking for the throttle body and cable kit.
Old Jan 7, 2011 | 02:32 PM
  #188
jksstar's Avatar
jksstar
I got my headers in today. Just some block huggers, less then 200 after shipping
Going to go over in the morning and see if they fit
Old Jan 7, 2011 | 04:12 PM
  #189
Quamen's Avatar
Quamen
I tried block buggers and the didn't fit on the driver side because they were aimed right at the power steering rack. Good luck though.
Old Jan 7, 2011 | 05:01 PM
  #190
jksstar's Avatar
jksstar
Maybe I will get lucky, what brand did you try? I know the hooker block headers won't fit, these fit alittle closer to the block.
We find out in the morning
Old Jan 7, 2011 | 07:35 PM
  #191
Havok_RLS2's Avatar
Havok_RLS2
Uh
Oh My....
Old Jan 8, 2011 | 10:56 AM
  #192
jksstar's Avatar
jksstar
They fit in fine but I see what you are talking about with them pointed right at the rack.
So I raised the motor 1" to see if I can get them to work. They will be tight and I will have to move some of the lines on the rack but I think I can get them to work.
Old Jan 8, 2011 | 02:13 PM
  #193
Quamen's Avatar
Quamen
I knew that they would fit in the engine bay. The outlets will end up having some nasty bends in them though which is why I ended up returning the block huggers. Figured why go through all that work to sacrifice performance in an area that these engines see good gains in.
Looking forward to results and how you route everything.
Old Jan 8, 2011 | 02:31 PM
  #194
jksstar's Avatar
jksstar
I'll see how bad the bends will be, if to bad I will send them back. Just from looking at it I think it will be ok since I raised the motor alittle.
I have to get my oil pan back before I do anything else. Would hate to get it back and then have to do more work to it.
Old Jan 9, 2011 | 02:39 AM
  #195
Quamen's Avatar
Quamen
Do you think you'll have any interference issues with the flex plate or TC shield?
Old Jan 10, 2011 | 04:27 AM
  #196
jksstar's Avatar
jksstar
Don't think so, more worried about the oil pan. It has a kick out on the pas. side to give me more oil cap.
Hopeing they will have it done this week so I can work on it some more this coming weekend.
Old Mar 26, 2011 | 06:56 PM
  #197
delslow1975's Avatar
delslow1975
so what was the out come on the headers?
Old Mar 26, 2011 | 07:09 PM
  #198
phreaktor's Avatar
phreaktor
Design Engineer
This thread needs videos....
Old Mar 26, 2011 | 11:30 PM
  #199
bbs350z's Avatar
bbs350z
in for more info on this
*ls swap in the works*
Old Mar 27, 2011 | 12:10 PM
  #200
delslow1975
so will the stock manifolds not fit with the swap? i know the stock ones will hurt on performance. but just dont want to spend a grand on headers when i plan on turboing it in the future.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
