Aftermarket Clutch and Slave Cylinder
Old Sep 1, 2009 | 06:45 AM
hackermb's Avatar
hackermb
Default Aftermarket Clutch and Slave Cylinder
Took my car, 2007 Base, into the shop today for an oil change and to have them look at the slave cylinder. Dealer said yeah the slave cylinder is bad and we will fix it, but we believe the problem is the aftermarket clutch is too heavy for it. They "Strongly Recommended" I replace the aftermarket clutch with a stock Nissan clutch for 680 bucks. My question to the forum is has anyone else had issues with the slave cylinder going bad because of an aftermarket clutch?
Any insight is welcome
Thanks
Old Sep 1, 2009 | 07:36 AM
*Boose*'s Avatar
*Boose*
I'm not 100% sure if it's the clutch. But there is a TSB on 07's for the slave cylinder.
Old Sep 1, 2009 | 08:41 AM
VO...'s Avatar
VO...
Administrator
Moved...
Old Sep 1, 2009 | 09:53 AM
hackermb's Avatar
hackermb
Yeah I have already had them replace it once or so I thought.
Old Sep 1, 2009 | 05:01 PM
musubi's Avatar
musubi
Thanks
Yes, there have been others who have broken their slave cylinder due to an aftermarket clutch. Most seem to be with the JWT clutch.
Questions, what aftermarket clutch are you using? You have any power mods? If so, curious to know what kind. And how many miles do you have on your aftermarket clutch? Thanks
Old Sep 2, 2009 | 04:57 AM
hackermb's Avatar
hackermb
I honestly don't know what aftermarket clutch I have. The previous owner installed it and I didn't think to ask him at the time. The only mods I have are test pipes and he installed those as well.
Old Sep 2, 2009 | 06:52 AM
mysmokenz's Avatar
mysmokenz
I have had my JWT clutch in for 25,000 miles I installed a new nissan slave cylinder at the same time. I have not had any problems with it!
Old Sep 2, 2009 | 02:28 PM
musubi's Avatar
musubi
the 07-08 Z's are running a different slave cylinder setup than the previous years and thus have been having issues since going to concentric type.
Old Sep 3, 2009 | 10:45 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I dont think it's a clutch issue, I think it's an a general issue with the design. It's still fairly rare to have a slave/master go bad, but it does happen from time to time.
Old Sep 8, 2009 | 01:04 PM
hackermb's Avatar
hackermb
Got it back on Friday and it was the concentric slave cylinder. All is better for now.
Old Sep 8, 2009 | 03:12 PM
musubi's Avatar
musubi
So is this your second time replacing the CSC? Are you planning on changing out the clutch?
Old Sep 14, 2009 | 04:33 AM
hackermb's Avatar
hackermb
Im not sure what they fixed the first time but I believe it was the CSC. This time it definitely was the CSC that was replaced. They suggested I go back to a stock clutch setup but I doubt I do that, especially if they keep fixing the CSC under warranty.
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
