Missing Nipple Piece on Plenum.. Replacement?
Old Sep 22, 2009 | 06:58 AM
J350z101's Avatar
J350z101
Default Missing Nipple Piece on Plenum.. Replacement?
Bought a Polished plenum and just went to install it and as I was getting it on and I realized this little nipple piece was not on it.. I tried taking it off my old plenum but that was a no go.. Can I substitute something in there or.. Any suggestions would be great:}
Polished Missing Piece - http://i37.tinypic.com/24b2mg9.jpg
OEM With Piece - http://i34.tinypic.com/vy5w74.jpg
Old Sep 22, 2009 | 07:00 AM
06blueZ's Avatar
06blueZ
its probably bonded in... that is for your brake booster, so you need to get that fixed somehow. maybe find the ID of the opening and get a piece of tubing and JB weld it in there?
Old Sep 22, 2009 | 08:56 AM
VO...'s Avatar
VO...
Administrator
If you can afford the downtime, I'd send the plenum back and ask for another one...
Old Sep 22, 2009 | 09:01 AM
J350z101's Avatar
J350z101
Bought it used from somebody local.. I had it in the garage for about 3months and I never realized it was missing it until the other day.. :{
Old Sep 22, 2009 | 02:01 PM
rcdash's Avatar
rcdash
I think you can use npt barbed hose fitting but you will likely need to tap it (probably 3/8" npt tap). Just find a fitting that is just a hair tight - either 1/4" or 3/8" from lowe's and get the tap to match (also at lowes). Make sure the hose end also fits snug before you drill out the plenum.
Old Sep 23, 2009 | 08:59 AM
VO...'s Avatar
VO...
Administrator
This sounds like a good idea. Tapping it would be a breeze. Make sure to use some type of sealant on the threads, like teflon tape...
Old Sep 23, 2009 | 09:04 AM
J350z101's Avatar
J350z101
This should be fun.. -_-
Rev_Night
Nov 7, 2020 06:00 PM
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
