transmission ideas for enduro car
Old Oct 19, 2009 | 10:42 AM
skywardracing's Avatar
skywardracing
Default transmission ideas for enduro car
We ran the 12 hours of the cascades in Portland Oregon this weekend in our 350 Z. The car has been fully developed with the exception of the engine and the transmission. As it turned out we blew two transmissions over the weekend. We limped in without 5th and 6th gear. Any ideas on how to improve the tranny? Are there any aftermarket transmissions out there that are reasonably priced?
Bryan
Old Oct 19, 2009 | 12:03 PM
terrasmak's Avatar
http://www.z1auto.com/prodmore.asp?m...ne&prodid=3790 here you go.
Old Oct 19, 2009 | 12:27 PM
qqqqball's Avatar
qqqqball
or you could buy 10 junk yard trannys for that price...not the girls... the transmission
Old Oct 19, 2009 | 01:47 PM
skywardracing
I like the idea of the squential transmission, but don't like the price.... Do you think a transmission oil cooler would help?
Old Oct 19, 2009 | 01:50 PM
NISMO_558's Avatar
NISMO_558
^ I dont think anybody makes a tranny oil cooler, but I could be wrong. The sequential tranny would have been my vote.
Old Oct 19, 2009 | 05:42 PM
terrasmak's Avatar
It may , just depends on why the failed on you. Was it a heat issue?
Old Oct 20, 2009 | 02:14 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
If you were abusing the stock tranny for hours on end without a cooler, then i would guess that it was a heat issue.
Running a car a car for hours isn't quite the same as a track day or time attack event.
I would suggest you get a 009 gearbox and fit it with a cooler kit (which you will have to custom make) and see how it goes from there. If you still have problems after that, then maybe that sequential box is the way to go.
Old Oct 20, 2009 | 03:34 AM
midz350's Avatar
midz350
((Quaife 6 Speed Heavy Duty Transmission 350Z))
((Designed for rear wheel drive applications capable of handling up to a maximum of 400 lb/ft and 450 bhp,))
Old Oct 20, 2009 | 03:42 AM
0jiggy0's Avatar
0jiggy0
I found that funny myself midz. Considering the stock tranny handles MUCH more then that. But maybe in a situation such as this enduro it would serve its purpose.
Old Oct 20, 2009 | 06:10 AM
SGSash's Avatar
SGSash
Vendor - Former Vendor
That's the rating they expect it to last indefinitely, in a very abusive racing condition shifting 20+ times a lap.
The stock gearbox couldn't handle that.
What gear oil were you using? I'm surprised you're blowing stock gearboxes - or maybe I've just had good luck. I've been using the same bone stock OE gearbox for 2 seasons now with 4 - 3hr enduro's and not once had an issue.
We use MT90 with 30% lightweight shockproof. Give it a try.
Drill the housing for a temp sensor and monitor the temps and if you're steady above 130 degrees C you'll need a custom cooler. Pickup off the drain plug, fill through the fill plug. Use a mocal or tilton diff oil pump and mount a setrab core in the back and you're done!
Old Oct 20, 2009 | 09:23 AM
skywardracing
We just got back from the race and have not torn open the transmission yet. I suspect we will rebuild one and then install a temp sensor as was suggested. I suspect we will end up installing a cooler. Thanks for the the feedback....
Bryan
Old Oct 30, 2009 | 01:21 AM
racer59's Avatar
racer59
try running a tremec tko600 we have run one for a while with 600hp no probs and u can get dog ring kits for them as well
SpartanZ32
Oct 22, 2015 09:36 AM
nissan1310
Oct 12, 2015 08:54 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
