Oil temp off factory ECU
Old Oct 27, 2009 | 08:37 AM
the7ferret's Avatar
the7ferret
Default Oil temp off factory ECU
Is there a lead comming off/to the ECU which one can tap for a oil temperature guage?
If not whats your recommendations for where to get the temperature?
Old Oct 27, 2009 | 09:52 AM
xzotklr's Avatar
xzotklr
To get an oil temp reading you install an oil filter sandwich; MOCAL makes an excellent one. The sandwich should accept AN fittings in order to have a line for oil temp.
Old Oct 27, 2009 | 03:45 PM
turbotoy's Avatar
turbotoy
I usually see them installed in the oil pan. A sandwich should work to.
Old Oct 27, 2009 | 04:36 PM
binder's Avatar
binder
http://www.innovatemotorsports.com/r...5_G35_350z.php
pin 8 off the sensor plug.
edit: that's oil pressure not temp. our cars don't have an oil temp sensor.
Old Oct 28, 2009 | 11:00 PM
dirtbikr's Avatar
dirtbikr
They most certainly do. Plug in any scantool worth its weight and you'll get an engine oil temperature read out in your choice of degrees or centigrade.
Old Oct 30, 2009 | 12:40 AM
bullant47's Avatar
bullant47
Default Oil Temp
Dirtbiker..Can you please explain that a little more please. I am TT and have the 350Z Haltech Platinum but still retain the standard computer. I also have a oil cooler with the Mocal sandwich plate alas no extra inputs for oil temp. I would like to know how I could utilise the oil temp function off the computer.
Thanks Ken (Australia)
Old Oct 30, 2009 | 05:27 AM
binder's Avatar
binder
I'll plug my LM-2 in and try again but after using it for 7 months now it has yet to let me log oil temp. If i could then i wouldn't have bought a secondary oil temp sensor.
The same way our cars do not report MAP to the obdII either.
Old Oct 30, 2009 | 05:30 AM
350z 6spd's Avatar
350z 6spd
I use cipher all the time to check my oil temp. My car is an 07 but I am almost positive that I have been able to log oil temp. on my friend's 06.
Old Oct 30, 2009 | 06:35 AM
binder's Avatar
binder
i checked on both innovate LM-2 and my BR-3 obdII dataloggers. Both are the same thing: oil temp not supported. Our cars don't support MAP either.
this is a 2003 car.
apex locator
Jul 23, 2021 02:27 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
