04 AT5 tranny in a 03 ?
Old Nov 30, 2009 | 05:01 PM
booger's Avatar
booger
Default 04 AT5 tranny in a 03 ?
I have an 03 G35 . Does any one know if 04 had two trannies ? I had thought there were two . Which code on the tranny is the early model ?
ThanKS !!!!
Old Dec 1, 2009 | 03:21 AM
duro78's Avatar
duro78
the cd00009 is the newer tranny. When mine was replaced it was replaced with the newer not sure on the previous part #.
Old Dec 1, 2009 | 03:23 AM
duro78's Avatar
duro78
Sorry didnt see the automatic part of the thread thought it was the 6mt
Old Dec 1, 2009 | 02:15 PM
booger's Avatar
booger
The 04 trany I was looking at had a #CD200 on it . Is it the newer or older version ?
Old Dec 1, 2009 | 02:17 PM
rcdash's Avatar
rcdash
If the TCM is integrated into the valve body it will not work. They changed mid year 04 (from separate TCM in the passenger side footwell, to an integrated TCM inside the VB). I think you'd have to update the ECM also if you wanted to use a new version of the TCM (and do some rewiring or get a new harness also).
Old Dec 1, 2009 | 02:20 PM
Jeff92se's Avatar
Jeff92se
Something happen to your tranny? You might have to either jack up the car and look for a number or see if you have the TCM in your footwell.
Old Dec 1, 2009 | 02:44 PM
booger's Avatar
booger
MIne is an 03 with the TCM in the footwell . I'll have to ask the guy that has the 04 tranny .
Jeff
I have a VB upgrade / Higher stall trq converter , and really dont like it any more . I no longer have the blower on the car and would rather have a smooth tranny
Old Dec 1, 2009 | 03:01 PM
Jeff92se's Avatar
Jeff92se
Then I think you're going to be stuck searching for another 03. I believe they changed all the trannys to the internal TCM type. But check the model numbers anyway.
Old Dec 2, 2009 | 06:07 AM
booger's Avatar
booger
Like rcdash said ....they changed mid year......early model 04 will work . The question is , how can one tell by looking at the tranny it self .
etkms
Jun 19, 2022 06:30 PM
seagrasser
Oct 11, 2015 03:27 PM
Ace2347
Sep 22, 2015 03:12 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
