A/T tranny failure!
Old Dec 16, 2009 | 03:19 AM
350Zdj's Avatar
350Zdj
Default A/T tranny failure!
Just wanted to know if anyone has ever experienced this?
My A/T started grinding and slipping last night. I lost some hp and the car has become less responsive. The moment i shift to "D" the tranny starts vibrating and the grinding noise becomes louder. Starting from a dig feels like im driving my civic.
Prior to this, I had jerky shifting from 1-2 and delayed+slippery shifting from 3-4.
What do you think went wrong? is it just the clutch? did i break any gear?
This guy from a A/T specialty garage quoted me 1400 to 2700USD to get it overhauled. He will also upgrade all clutch which can handle turbo setups and offered me 3months warranty. Before i grab this offer, i would like to know what do you guys think...
thanks much!!!
Old Dec 16, 2009 | 03:43 AM
0jiggy0's Avatar
0jiggy0
Sounds like you had AT tranny failure.
If it felt wrong why did you keep beating on it? These AT's are brutes, the fluid was probly low.
Old Dec 16, 2009 | 04:02 AM
350Zdj's Avatar
350Zdj
Good question. Maybe i was just too stupid to ignore the symptoms. I thought it was normal for an abused tranny (tracked my car several times).
Fluid is fine - just flushed it a month back...
Old Dec 16, 2009 | 04:05 AM
0jiggy0's Avatar
0jiggy0
Its a hell of a coincidence that you flushed it a month ago and now it failed. I bet it was low.
Old Dec 16, 2009 | 04:12 AM
350Zdj's Avatar
350Zdj
^I see.... Then i shall double check that when i get home
Old Dec 16, 2009 | 05:20 AM
rcdash's Avatar
rcdash
There is a specific method for checking the AT fluid level based on temperature of the fluid while the car is running. Check the FSM. I also feel that there is a good chance you have been running with low ATF levels, which caused your clutch packs to burn out.
Old Dec 16, 2009 | 05:30 AM
Z04's Avatar
Z04
you can check, but what you describe sounds like your tranny is fried and continued driving will cause it to totally fail. start looking for a replacement.
Old Dec 16, 2009 | 06:13 AM
You need either a rebuilt or new transmission. Or one from a 350Z with low miles.
Old Dec 16, 2009 | 07:09 AM
exZilaration's Avatar
exZilaration
Not good. Same thing happened to my Z.
If the fluid is low you did some damage to the tranny.
Is the tranny starting to have that loud whine almost like a supercharger?
Old Dec 16, 2009 | 07:20 AM
Entaille's Avatar
Entaille
this must be a troll thread, he lives in dubai, obviously he drives something 10x more expensive then a Z ! : )
Old Dec 16, 2009 | 07:47 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Might as well get rebuilt and upgraded, and throw on VB upgrade while your at it.
Thats what i would do...
Old Dec 16, 2009 | 08:02 AM
350Zdj's Avatar
350Zdj
thanks for the feedback guys!
this is what happend few months back - my radiator internals broke and the ATF and Coolant mixed together, made their way towards the tranny. I was cruising down a highway when this happend.... I started losing power and the Z just started to slow down.
By the time I found a proper parking, the gear was sounding like a supercharger. I took it to a garage to flush the whole system. After that, the tranny seemed ok. There must have been already damage and it just kept getting worse. . .
so basically it's just what u guys suspected - low on atf... you are right
could this have broken any gears? im hoping the tranny rebuild kit will fix this?
@ exZilaration - when you built your tranny did you have to do the full rebuilt kit? how much do these things really cost?
oh and BTW Entaille.. No. I don't own Lambo's and stuff.. i'm just one of those peasants who are trying to make a living in dubai.
Old Dec 17, 2009 | 09:07 PM
exZilaration
350zdj my warranty covered it.
seagrasser
Oct 11, 2015 03:27 PM
Ace2347
Sep 22, 2015 03:12 AM
rizzla
Drag
Sep 17, 2015 08:44 AM
