revup with 7400RPM question
Old Jan 11, 2010 | 06:06 PM
Dark9t's Avatar
Dark9t
Default revup with 7400RPM question
stock 06 revup g35 can rev up to 7400RPM with utec?
Old Jan 11, 2010 | 06:37 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
a better question would be why bother
to do it with a utec on a revup, you'll need to use the TXS Map Sensor in conjunction with the MAF.
Old Jan 11, 2010 | 08:34 PM
hellsoldiers08's Avatar
hellsoldiers08
just because you raise the rpm doesnt mean more power.......unless with supporting mods
Old Jan 12, 2010 | 12:38 AM
Dark9t's Avatar
Dark9t
what kind of supporting mods do i need?
i am getting utec,Mrev2+specer,HFC,exhaust and 4.083 Gears after Tax return
Old Jan 12, 2010 | 12:41 AM
Dark9t's Avatar
Dark9t
Get a Pro to tune it after all those mods too
Old Jan 12, 2010 | 05:02 AM
AZHR's Avatar
AZHR
im still lost on the whole " rev up to 7400" part...why?
Old Jan 12, 2010 | 05:03 AM
cdoxp800's Avatar
cdoxp800
And Cams.
Old Jan 12, 2010 | 05:14 AM
Z1 Performance
Former Sponsor
leave your rev limiter exactly where it is
Old Jan 12, 2010 | 07:17 AM
Dark9t's Avatar
Dark9t
Won't make power after 7000? Not even 7200rpm?
Old Jan 12, 2010 | 07:52 AM
jonnylaw's Avatar
jonnylaw
no.
Old Jan 12, 2010 | 01:49 PM
rocks's Avatar
rocks
It may not make power past 7000 rpms but the power wont just drop off. I have my rev limiter set at 8500. I shift at 8000 rpms in 1st and 2nd gear, 3rd gear i shift around 7400. It keeps the car in the power band. This is with mild cams and a low compression engine. I knocked over a half second off my 1/4 mile time doing this.
Old Jan 12, 2010 | 01:53 PM
Z1 Performance
Former Sponsor
But you have cams and he doesn't. On stock cams, it's a waste of energy
Compression does not affect the relative power curves by much. The difference between 9:1 and 10.3:1, assuming pump gas, is not going to be a tremendous amount assuming both cars are remapped
As for mild cams, that is a very relative term. Yours are far more aggressive than stock, which is the benchmark for the OP
Old Jan 12, 2010 | 02:29 PM
rocks's Avatar
rocks
I understand your argument. But raising the rev limiter also helps from running up against it. I would raise it to 7200 rpms and still shift at 7000, then you have the extra 200 rpms to keep you from hitting the fuel cut. The maxima guys shift stock engines at 7500-8000 rpms. But if you want OEM reliable performance then don't touch it.
I had a utec on a my revup as far as I know you can not change the rev limiter on it, at least it couldn't when I had it. They may have updated it. But for a revup utec is not so good. Get uprev and remap your stock cams.
Old Jan 12, 2010 | 02:35 PM
Z1 Performance
Former Sponsor
But are Maxima guys making power at that rpm, or are they just shifting them there? If not making power, how far of a sweep is there between peak hp and shift point? 7200 I agree is a sensible level. Taking it much above 6800-7000 or so assuming stock exhaust manifold is going to be good for noise, but not much else. Not to mention with standard revup cams, he is already trading a smidge of top end power for a fatter mid range with the inclusion of a non revup middle manifold section
Old Jan 12, 2010 | 02:42 PM
NISMO_558's Avatar
NISMO_558
8500 damn
Old Jan 12, 2010 | 03:25 PM
Dark9t's Avatar
Dark9t
Thanks for all the replys, after all this, I think I am gonna stay at 7000rpm.
Old Jan 12, 2010 | 03:56 PM
rocks's Avatar
rocks
No they are not making power up there, as far as I know. But you get a few extra rpms to play with, without bouncing the limiter. I don't shift at 8500 haha. Can't really let people drive my car now. Afraid they may blow it up with no limiter on it hahaha. I wish I could afford bigger cams, to run it up too 8500 making power.
Old Jan 17, 2010 | 11:30 AM
evil00017's Avatar
evil00017
So what about going to 7400rpms on a supercharged 350z?
Old Jan 19, 2010 | 08:39 AM
vthao's Avatar
vthao
Dark, with the 4.083 gears man, I'd say kick the rev-limiter to 7400 RPMS. I have the gears; they're awesome but would benefit even more from a higher rev-limiter. If you're planning to stick to the OEM gears, stay at 7k.
Old Jan 19, 2010 | 10:48 AM
rcdash's Avatar
rcdash
Even if torque is decreasing at high rpms, you can still benefit from higher revs because of the prolonged torque multiplication of the lower gear ratio. It's the torque at the wheels that matter, not engine torque.
+1 to UpRev Osiris reflash
-1 to the UTEC
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
