240sx Final Drive Gear in a 350Z Diff?
Old Feb 9, 2010 | 05:50 PM
Corbic's Avatar
Corbic
Default 240sx Final Drive Gear in a 350Z Diff?
Seeing both use the R200 Rear-Diff would it be possible to swap the ring gear and pinion from a 240SX (4.083) into the 350Z (3.538)?
I'm asking because 240 Diffs are like $40, compared to a ring set for the Z which sells for $600.
Old Feb 9, 2010 | 07:19 PM
twitch579's Avatar
twitch579
http://www.g35parts.com/Nissan-4-083...8100-4083x.htm This is where I ordered them from.
I believe these are 240 gears, I had them on my car for a while and they worked perfect. Pulled them for N20.
Old Feb 9, 2010 | 08:21 PM
Italianjoe1's Avatar
Italianjoe1
I thought 240s used the smaller R180 diff?
Old Feb 10, 2010 | 03:38 AM
Corbic's Avatar
Corbic
Nope, R200.
Old Feb 10, 2010 | 10:16 AM
*Boose*'s Avatar
*Boose*
Someone let me know. There's a lot of wrecked 180's here with sr20's.
Old Feb 10, 2010 | 11:03 AM
04fairlazdyz's Avatar
04fairlazdyz
LOW N SLO
This would be good to know!
Old Feb 10, 2010 | 01:30 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
ring and pinions for the 240SX will not fit 350Z/G35's - ring gears take a different bolt, pinions are much smaller in diameter
Old Mar 27, 2010 | 07:43 PM
anotheraznguy's Avatar
anotheraznguy
do you know if the ring and pinion from the 350z will fit the 240sx? hehehe.. i know that the bolt diameter is 1mm bigger on a q45 r&p and we just drill out the diff to fit. but was wondering if that was true with the z.
Old Mar 27, 2010 | 07:50 PM
Z1 Performance
Former Sponsor
the pinions, pinion bearings and pinion flanges (for driveshaft) are totally different and not interchangeable
bcoffee20
Nov 19, 2015 06:39 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
3vilbunny
Sep 13, 2015 12:31 PM
OperatorAF
Sep 13, 2015 11:36 AM
