Grounding kit
Old Feb 12, 2010 | 02:09 PM
myfirstzcar's Avatar
myfirstzcar
Default Grounding kit
Could someone please tell me if a grounding kit would be worth getting. I have an 03 touring 6mt with 30,000 miles, I want it to idle smooth in closed loop. As of now it seems a bit rough. It has new plugs, a motordyne spacer and no codes......Thank you.
Old Feb 12, 2010 | 02:23 PM
NISMO_558's Avatar
NISMO_558
Not worth it
Old Feb 12, 2010 | 03:02 PM
CSF's Avatar
CSF
I don't think it's worth it either unless you are running some heavy audio equipment. Since all you have is the MD Spacer, I'd start with checking any hoses for leaks.
Old Feb 12, 2010 | 04:17 PM
This should explain it.
Old Feb 12, 2010 | 04:22 PM
calin's Avatar
calin
Not really worth it in my opinion. I have one and it made my idle a LITTLE bit smoother than before, but I don't think it was worth the $80 I spent for it. If your idle is pretty rough, then maybe it's worth it to you. It all depends on if you're willing to spend the money or not.
Old Feb 12, 2010 | 04:59 PM
s31t8n8's Avatar
s31t8n8
doesnt really do anything, just makes the engine bay look a little nicer. I bought one only because a forum member was selling it for cheap
Old Feb 12, 2010 | 06:42 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
thats your opinion I think the colored wires running every where look cheap
i don't think they provide any large benifits unless you already have grounding "issues". I bought a grounding kit only because I tucked my wires and moved/changed a bunch of ground points, I bought a smoke color kit i only used a few of the wires and tried to keep it as hidden as possible so it looks clean not like some crap you threw on your engine.
Old Feb 12, 2010 | 06:45 PM
sdZ33's Avatar
sdZ33
I don't know about it looking cool, but you could benifit from it if you have a heavy system... That's probably the only reason I did it... If anything, please don't spend the $80+ for a "KIT"... Just make your own...
Here is a link.... http://www. 3 5 0 z - t e c h . com/zwiki/Tutorial:Grounding_Kit_Installation
Old Feb 12, 2010 | 07:42 PM
secwind's Avatar
secwind
I read somewhere on G35Driver about this. Some people saw improvement in throttle response and AT shift time. It's just a physiological mod imo.
+1 on making your own.
Old Feb 13, 2010 | 12:49 AM
s31t8n8's Avatar
s31t8n8
what can i say, i like rice
Old Feb 13, 2010 | 01:16 AM
Motormouth's Avatar
Motormouth
no.
besides looking ridiculous, and extremely ricey, they do nothing.
Old Feb 14, 2010 | 04:03 AM
duro78's Avatar
duro78
The only benefit is making your electrical system more effecient. Upgrading my stock grounds did make a difference. Did it my self using 0 gauge but it was done to upgrade my electrical(music) not for performance gains
Old Feb 14, 2010 | 11:22 AM
vdemon311's Avatar
vdemon311
I think the benefits are only seen in the shift of At transmission. Electrical flow is improved, but barely noticeable I installed the Stillen grounding wires and It barely did anything (slightly smoother idle, but not really). If you want a noticeably smoother idle , I recommend going with a nice osiris standard tune. If possible, get it tuned at a shop on a dyno.
Old Feb 14, 2010 | 11:41 AM
nismo_nate's Avatar
nismo_nate
i have a set of stillen ground wires in my car.. didn't notice anything.. but hey its another mod to check off my list lol
check ebay often. thats where i got mine for $40
Old Feb 14, 2010 | 06:33 PM
myfirstzcar
Wow! Thanks everyone for the replies. I think I'll change the plugs and get a tune then. It runs exactly the same as before the spacer, except it really is a tad bit snappier. I already checked the hoses and did a smoke test, it's all good there.
Old Feb 15, 2010 | 06:11 AM
350junkie's Avatar
350junkie
when i put my spacer in I didn't raise the tower? bar enough and it rubbed a little on the upper plenum causing a rougher idle. 2 washers fixed my problem.
Old Feb 16, 2010 | 04:24 AM
Synjn's Avatar
Synjn
NO!
Old Feb 16, 2010 | 04:29 PM
terrasmak's Avatar
pointless
Old Feb 17, 2010 | 08:51 AM
Ronin82's Avatar
Ronin82
its not really worth 80$, you can get the same kinda wire/size gauge much cheaper and do it yourself.
I have it and I wanna say it idles smoother but to be honest its really hard to tell. I did read somewhere here that the early 350z's weren't grounded very good as the later models. you will get NO performance gain but may improve electrical effiency. but still not worth the $$$ I see them go for
Old Feb 17, 2010 | 09:04 AM
Z_flip's Avatar
Z_flip
DIY kit... you can buy some cables from audio shops for cheap.
