4.083 Gears
Old Feb 15, 2010 | 08:09 PM
RedlineAZ's Avatar
RedlineAZ
Default 4.083 Gears
I have had my 4.083 gears installed for about 5k miles now in my 06 enthusiast w/ VLSD. They are amazing, and I love them, but I am having an issue and I don't know if any of you guys are experiencing this too. Sometimes when under normal to moderate accelerating with traction control ON, it goes into SLIP mode, even if traction is not being broken at the time. If I turn traction control off, there's never an issue. It usually happens around 3k rpms. Is this an easy fix (besides turning traction control off everytime I get into the car), or is it something thats not a big deal. Thanks for the help!
Old Feb 15, 2010 | 08:11 PM
Steve-O Z33's Avatar
Steve-O Z33
Traction control may read output shaft speed related to flywheel speed. Just a guess.
Old Feb 15, 2010 | 08:12 PM
TheFarmer's Avatar
TheFarmer
What size tires are you running front and rear?
Old Feb 15, 2010 | 09:05 PM
RedlineAZ's Avatar
RedlineAZ
Fronts: 245/35/19 tires on 19x8.5 rims +17
Rears: 275/35/19 tires on 19x10 rims +22
Old Feb 17, 2010 | 11:30 AM
RedlineAZ's Avatar
RedlineAZ
No body else is having this issue?!
Old Feb 17, 2010 | 11:34 AM
2fasst's Avatar
2fasst
I don't see how this can be related to your regearing or LSD. You indicated normal acceleration so your tires are not breaking traction.
The only thing I can think of is perhaps the speed sensors on ONE of your axles may have debri or damaged during the install and your ECU thinks one wheel is slipping.
Old Feb 17, 2010 | 11:42 AM
JasonZ-YA's Avatar
JasonZ-YA
Check to ensure the sensors are mounted tightly and evenly on the diff.........
those sensor are what determine slip.........maybe one was damaged or loose from the install......
there are two of them, one on each side of the diff.....
-J
Old Feb 17, 2010 | 12:29 PM
JasonZ-YA's Avatar
JasonZ-YA
The two sensors im referring to are located here:
there is one bolt on each one, they are tear drop shaped........just like the milled area circled..
-J
Old Feb 17, 2010 | 12:31 PM
2fasst's Avatar
2fasst
Also check the 'speed gears' on the axle that these sensors read for any debri or silicone that may be on it by the installer when the sealed the diff cover.
Old Feb 17, 2010 | 12:36 PM
JasonZ-YA's Avatar
JasonZ-YA
^ ya...good one......agree....
process of elimination time man......
-J
Old Feb 17, 2010 | 12:39 PM
Italianjoe1's Avatar
Italianjoe1
-J
Gonna find your problem here. I'd bet on the dirt/contamination thing. If there's something making one sensor skip a tooth or two, it sees that as slower rotation and would think the other side is slipping.
Old Feb 22, 2010 | 04:34 PM
RedlineAZ's Avatar
RedlineAZ
Awesome, thanks for the advice guys! I will get underneath there and check it out tomorrow if I get the chance
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Bigsyke
Sep 11, 2015 06:19 PM
