sad... car can be "shifted but" does not go anywhere... Clutch issues HELP DIAGNOSING
Old Feb 26, 2010 | 03:18 PM
SoldzMyZ's Avatar
SoldzMyZ
Default sad... car can be "shifted but" does not go anywhere... Clutch issues HELP DIAGNOSING
Long post, anyway, last week, it seemed as though i smelling the burning clutch. Now mind you I've been driving my current 350z for 4 years now and all of the sudden, everytime I drive, I smell that burning clutch smell, similar smell I used to get when I was learning to drive this car 4 years ago.
This week it got worst. It seems like my car lost power. I would put it in 1st gear or any gear mind you and it takes forever to get the car going. Like I would need to raise the car to 3-4k to make the car go. It basically feels like i'm driving a slooooow car to get it going and i'm reving it high just to get it going.
Anyway, you know how the Z's first gear is hard to get into when its stock and working fine? I mean, you have to either come to a full stop to get it into first gear, then it'll go in and you can go.... Now that its not working i can put it in first and go (of course I have to rev it to 3k to get going).
Now I had to drive to my parent's home today (I live 50 miles away from them and go to school) and drive home. Yup my car feels totally different, like going on to a hill on the 405 into the San Fernando Valley, I have to literally downshift to keep going.
Also, when I have to rev high to keep up with traffic, my clutch pedal became SUPER SOFT I mean, SOFT. Like our Z clutch is normally stiff and has resistance compared to other manual cars i've driven, it basically felt like the clutch in my friend's rav 4.
Go home, made it fine...
So I thought. I park on the drive way, go inside, eat, play with dogs. I go outside to put the car in garage so I can work on it, flush the clutch fluid as it is dirty in the reservoir.
Start the car... It starts, put car in gear, does not go anywhere. 1,2,3,4 5,6 gears... Even reverse gear does't work. I can move the shifter into the 1st or any other gear even reverse without stepping on the clutch. The car basically does not go anywhere. Engine sounds fine, there's no leaks, in the clutch reservoir or anything.
SOOOO
Any help out there?
I'm gonna wait for my pops to come home and help me push the car since its in between the driveway and the street.
Old Feb 26, 2010 | 04:55 PM
hellsoldiers08's Avatar
hellsoldiers08
hmm maybe a far idea but my brother 07 Z csc went out completely (thank god he was in the neighborhood) Also maybe a linkage thing :/?? Idk im just throwing some ideas out there. I hope you get it sorted out, good luck!
Old Feb 26, 2010 | 06:35 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
when you were driving it and gave it more gas did it rev up but not go any where? If so its a good chance your clutch needs to be replaced.
Old Feb 26, 2010 | 06:38 PM
• clutch disc is broken completely
• internal transmission damage
• failed clutch master cylinder
• failed clutch slave cylinder
• broken clutch cable
Old Feb 26, 2010 | 07:29 PM
MTZ33's Avatar
MTZ33
Shift linkages are fkedddd... shift fork maybe... regardless, take it apart, replace clutch and go from there...
Old Feb 27, 2010 | 02:18 PM
winchman's Avatar
winchman
By not dealing with the slipping clutch in a timely manner, you've probably damaged a lot of other stuff.
Check to see if your school offers a course like "How to take care of something really nice so it doesn't turn into a worthless POS". You need it.
Old Feb 27, 2010 | 02:22 PM
JCat's Avatar
JCat
A slipping clutch will burn your flywheel....and your flywheel is expensive to replace.
Old Feb 27, 2010 | 02:24 PM
SoldzMyZ's Avatar
SoldzMyZ
I know :-(
lesson learned. OUCH.
Old Feb 27, 2010 | 02:25 PM
SoldzMyZ's Avatar
SoldzMyZ
thank you mr. ********
Old Feb 27, 2010 | 02:39 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
It's amazing that so few responses can elicit such misinformation
My not-so-technical, it's 7 pm on a Saturday and I'm tired, evaluation based on everything you've described
your clutch is SHOT
you need a new one immediately. The flywheels are not resurfaceable, so hopefully yours is still intact (assuming budget is a primary concern, if not, there are several good quality aftermarket units)
Old Feb 27, 2010 | 03:15 PM
SoldzMyZ's Avatar
SoldzMyZ
your clutch is SHOT
Thank you, I got it looked it with my family mechanic and you sir are correct!!!
Ace2347
Sep 22, 2015 03:12 AM
