Raising idle rpm's with Consult II
Old Oct 30, 2003 | 03:15 PM
g356gear's Avatar
g356gear
Default Raising idle rpm's with Consult II
I have heard differing opinions about consult II idle rpm adjusting. Some say it is a temporary setting that reverts back to stock after a certain amount of time.....some say it is a new permanent parameter in the ECU. What is the scoop???
Old Oct 30, 2003 | 03:28 PM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Default Re: Raising idle rpm's with Consult II
It is a new permanent parameter in the ECU. I can see it when working on the car. It also will not lose it's memory if the battery is disconnected.
Old Oct 30, 2003 | 06:21 PM
apex locator's Avatar
apex locator
yup its permanent
Old Oct 31, 2003 | 05:33 AM
g356gear's Avatar
g356gear
I did see a post on this board by a z owner who took his car in to a dealer to have this done and the tech said it was a diagnostic tool only and not a programming tool. Maybe he was blowing smoke.
Old Oct 31, 2003 | 05:35 AM
Jeff@Performance
Performance Nissan
He didn't know what he was talking about!!!! There are several things you can change, including idle and timing.
Old Nov 1, 2003 | 04:48 AM
350Zzzz's Avatar
350Zzzz
Professional
Not heard of the consult II idle rpm adjuster. Why not just take the car to a dealer service and get them to either increase or decrease the idle timing; Which is what I did after installing the pro charger, as the idel timing become very rough with the forced induction and I asked that my idel timing to be increased slightly?
Gerald
Old Nov 1, 2003 | 09:09 AM
jawbone's Avatar
jawbone
Consult II is the standard diag tool to work on nissan products. You can reflash target idle and timing, lots of other bi-directional capabilities. You can buy one, just a paltry 4grand.. but gotta have one if you do a lot of Nissan stuff.
Old Nov 14, 2003 | 08:36 AM
sadwoman1's Avatar
sadwoman1
Any idea where to buy a consult II
Old Nov 14, 2003 | 08:54 AM
spazpilot's Avatar
spazpilot
you can adjust idle but only retard riming. If you advance the timing it will revert back.
Old Nov 14, 2003 | 09:01 AM
stx's Avatar
stx
You can advance it. It will only revert back if you try to advance it more than its range.
Old Nov 14, 2003 | 01:53 PM
FLY BY Z's Avatar
FLY BY Z
thats right, mine is advanced 2 degrees for a few months now. the tech this week said he thought he did it 3 degrees. I hope it's two.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
Justin100
Nov 29, 2015 03:58 PM
Inspatatrac
Sep 8, 2015 02:12 PM
