Welded vs tomei 2way
Old Apr 22, 2010 | 01:06 PM
sir_vq's Avatar
sir_vq
Default Welded vs tomei 2way
I know this was prob discussed somewhere. But I would like to hear peoples opinions on this perticular question, please don't tell me what your boys opinion is or what you heard cause quite frankly there to Many fan boys on here stating illiginmate opinions my question is: I have a welded open diff I feel like it's to violent for daily driving. I also have a 2way uninstalled if I install the 2way will it be more streetable.... I know it gonna lock up on low speed turn like the welded does but is it as uncomfortable as the welded on is
this car must be daily driver but I would still like to hit some local events when I can please give me honest opinion only if u have experince with both welded and 2ways thanks in advance
Old Apr 22, 2010 | 02:21 PM
ATX350's Avatar
ATX350
Hey Sir, I'm on a welded diff also so can understand your suffering lol. I haven't used the Tomei but Josh from Nevrslo Motors uses it. I'll PM him and ask him to update this thread with his experience.
Old Apr 22, 2010 | 03:43 PM
bardabe's Avatar
bardabe
My experience with a Welded Differential on a 240sx and a KaaZ 2way LSD. is pretty much the same. Honestly if you are going to drift the car just suck it up and run the welded. However if you are going to use the car, for Cayon Racing, Autocross, Road racing etc etc. I would honestly get a 1.5way LSD.
a Welded LSD is always Locked, a 2 way is locked under acceleration and Deceleration, only real difference being that the 2way unlocks for a split second going from the acceleration to deceleration position of clutch packs.
streetability will suck with both.
my $.02
Old Apr 22, 2010 | 03:54 PM
LovinMyZ's Avatar
LovinMyZ
welded is pretty harsh for daily and my buddy's welded diff blew a whole and locked up while on the freeway, that is pretty scary. if i were you id just save up money for a carbonetics. from experience i can tell you they are bad ***, they do the job and dont make a single noise or play it safe and use a pop that 2 way in there
Old Apr 22, 2010 | 04:58 PM
bardabe's Avatar
bardabe
I feel bad for your friend, and ive seen it happen. that's what happens when people don't weld and prep the differentials properly. I've welded over 50 differentials now with absolutely zero failures. 2 are on RB26 cars used in Drag racing and Drifting. it all comes down to technique just FYI be careful who you trust to weld a differential.
I agree with you 100% on the Carbonetics though.
Old Apr 23, 2010 | 04:59 AM
sir_vq's Avatar
sir_vq
I. Heard you can shim the vlsd to make them a 1.5 does anyone know of this?
Old Apr 23, 2010 | 07:08 AM
bardabe's Avatar
bardabe
oldest trick in the book, guys in japan have been doing this since the early 90's but yeah it can be done.
Old Apr 23, 2010 | 01:22 PM
sir_vq's Avatar
sir_vq
Is there info on how to do this on this forum, or maybe direct me to the correct place,
Old Apr 23, 2010 | 06:08 PM
bardabe's Avatar
bardabe
http://zilvia.net/f/s-chassis/200226...-j30-vlsd.html
this is an R200 Differential from a J30 into a 240sx y popular part. it will be the same exact Procedure just of couse with the 350Z parts. which I'll let you get part numbers for because I'm wayyy too lazy to do more searching as of right now.
enjoy, if you have any questions feel free to ask.
Old Apr 24, 2010 | 05:39 AM
sir_vq's Avatar
sir_vq
^^^^^^^ thanks u the man..... Ok newest prob while putting diff back in my boy lost balence of the diff on the deadman, when it feel the part that the driveshaft connects to bent I tried to remove my other one but the brass dust sheild are diff, does anyone know where to get that peice that slides onto the pinion gear and connects to the DS? Are the different between the open and vlsd ones thanks for the help guys
Old Apr 24, 2010 | 09:40 AM
sir_vq's Avatar
sir_vq
got part numbers no need to respond thanks anyway, i'd still like to hear peoples opinion on the original topic
Old Jun 16, 2011 | 11:08 PM
almost3flips's Avatar
almost3flips
resurrection bump.....anyone else done this?
AbrasiveRaysive
Sep 20, 2021 02:29 PM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
hardkicks
Sep 20, 2015 12:28 PM
Suffolk350z
Sep 13, 2015 02:43 PM
Sep 2, 2003 02:33 PM
