is this normal?
Old May 24, 2010 | 04:35 PM
JDMStanced's Avatar
JDMStanced
Default is this normal?
i drove a 03 350z track model. Whenever i try to shift fast, it grinds.. FYI, i drove WRX for 2 yrs.
I kinda feel the delay when press in the clutch and trying to shift fast. It feels like the clutch doesn't engage fast enough. Possibly clutch wear? or is it normal?
I drove about 3 350zs so i'm not sure about the feeling.
Old May 24, 2010 | 05:08 PM
hellsoldiers08's Avatar
hellsoldiers08
hmm sounds like your not lifting your foot off the clutch fast enough... i only get a grind when i dont lift off fast enough when shifting gears. Also, wrx and a 350z clutch are not the same. Like the car god said not all Clutch systems are created equal. amen :0P
Old May 24, 2010 | 05:14 PM
T-Stan's Avatar
T-Stan
my brother has a 2005 wrx, the clutches are totally opposite, the wrx is much smoother than the 350z. imo.
Old May 24, 2010 | 05:40 PM
adamc's Avatar
adamc
I love the way the BMW's feel... smoooooooth
Old May 24, 2010 | 05:54 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
If I remember correctly, that's kind of problem with at least the '03s. I had an '05 and never had the problem. Well, except for when I let the clutch out too quickly.
Old May 24, 2010 | 06:28 PM
JDMStanced's Avatar
JDMStanced
i drove 06 and didn't grind. How much would it cost to fix the grinding?
Old May 24, 2010 | 06:52 PM
JDMStanced's Avatar
JDMStanced
ALso, when i keep the RPM at a certain number for awhile, it doesn't stay vroooooooooooooooooooooooo. It goes vroo vroo vroo... what causes this?
Old May 24, 2010 | 07:27 PM
I am thinking you should stay with the WRX.
Old May 24, 2010 | 07:35 PM
JDMStanced's Avatar
JDMStanced
if it's normal then i can bear with it. But if it's not, then i'll have to find another way?
Old May 24, 2010 | 08:53 PM
The 350Z clutch-transmission is notchy. You have to work the clutch and shift just right. You might say that it is finicky.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
