Which Oil do you run ?
Old Nov 6, 2003 | 12:41 PM
350trackz's Avatar
350trackz
Default Which Oil do you run ?
What experiences have you found with the oils vailable ?
Mobil 1
Royal Purple
Red Line
Others ?
Old Nov 6, 2003 | 12:55 PM
orhanz33's Avatar
orhanz33
i've heard royal purple is good stuff, but majority of the people i talk say amsoil is real good....i think i'm gonna order that in bulk from their site...
Old Nov 6, 2003 | 02:07 PM
Audito350Z's Avatar
Audito350Z
used Mobil 1 0W30 or 5w30 in my Audi A4 1.8T
now running Redline 10W40 in the 350Z
PeteH
Old Nov 6, 2003 | 02:16 PM
FLY BY Z's Avatar
FLY BY Z
We use Mobil 1 in the race cars and I also use it in the Z. I use cheap poopy in the truck.
Old Nov 6, 2003 | 02:36 PM
quangquoclu's Avatar
quangquoclu
Newbie
mobil one
Old Nov 6, 2003 | 02:55 PM
lemonjihwan's Avatar
lemonjihwan
so Mobile1 is the best oil for 350z?
or mobile 1 is most often used oil for Z?
Old Nov 6, 2003 | 03:30 PM
FLY BY Z's Avatar
FLY BY Z
Of the high end oils Mobil One is the most resonable priced, the most readily available, and can go long enough, protect thouroughly enough, and in a close enough way to the real expensive oil that is seems to be the logical choice for all those but the most lubracativelly ****.
Old Nov 6, 2003 | 03:34 PM
dwnshift's Avatar
dwnshift
Mobil 1.........period
tranny
rear end
and engine
SRF brake fluid
Old Nov 6, 2003 | 05:33 PM
Z'd's Avatar
Z'd
Amsoil- everywhere- engine, tranny & diff!!!!!
(Yes, I have used Mobil One and Castrol- Amsoil is my choice. Join the preferred buyer club and then order up what you need and the price will be comparable to Mobil One.)
Old Nov 6, 2003 | 06:01 PM
WOTM's Avatar
WOTM
I also use Amsoil. I have put it in my BMW, Supras and F250. Never had a problem in any car.
Old Nov 6, 2003 | 06:05 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Mobil one synthetic, it's easy to find, and I want to be sure to run the same oil from now on. If it's some hard to get oil, that would be difficult.
Old Nov 6, 2003 | 06:18 PM
troy49er's Avatar
troy49er
Mobil 1 Synthetic 5w-30....
$3.77 / Qt. @ Local Target Store
Old Nov 6, 2003 | 06:58 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I run Castrol GTX 5w-30...only 1.79 a quart...
I originally ran Castrol GTX 5w-30 in my 97 Maxima and then switched to Mobil 1 5w-30.
I had any oil analysis done on each oil after a 5,000 mile interval and the engine showed just about exactly the same wear characteristics with both oils....and a few wear metals were even higher in the Mobil 1. I don't think synthetic is worth the extra $$ you drop on it.
Furthermore after seeing the inside of a VQ30DE motor with 171,000 miles on in and still being able to see the factory etching on the cylinder walls...I don't think it really matters what oil you use unless you plan on running your car WELL over 200,000 miles.
Old Nov 6, 2003 | 07:54 PM
MY350Z.COM's Avatar
Royal Purple in the engine, tranny, diff
Get it @ Z1 Performance
http://www.z1auto.com
Old Nov 6, 2003 | 08:03 PM
lemonjihwan
whats difference between 5w30 and 10w30???
Old Nov 6, 2003 | 09:00 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
about 5w's
Old Nov 7, 2003 | 05:31 AM
keiffer953's Avatar
keiffer953
Mobil 1 Synthetic 5w30
Old Nov 7, 2003 | 05:32 AM
ttsupra94's Avatar
ttsupra94
Aren't you just supposed to use the oil the dealership uses for the first 10k miles? I thought i saw that somewhere on the forums before. I'm still under 10k, but then I might switch to something else.
Old Nov 7, 2003 | 05:43 AM
Audito350Z's Avatar
Audito350Z
these are multi-viscosity oils... the 5w is not as thick at 10w when it's cold, so it has a tendency to be moved a little faster by the oil pump when you first start the car
when the oil is up to temp, it will act as a 10w (10 weight) oil
some race teams use single viscosity oils.... you might hear them talking about 30 weight, 40 weight or even 50 weight oils for their race engines... that's the same as the 10w in the multi-viscosity name... those oils are thick all the time
Hope that helps,
PeteH
