Metal Grinding noise in 5AT
Old Jun 19, 2010 | 09:29 AM
sjthegreat1's Avatar
sjthegreat1
Default Metal Grinding noise in 5AT
Hey guys need some help.I have a 5at and everytume i put the car in R or D from P it makes a grinding noise.It sounds like some metal grinding against each other.It drives fine though.Ill take a video or sound clip later tomorrow.Please let me know if you guys have dealt with something like this as it seems like its getting louder and louder and it happens everytime i change to R or D or vice versa.Thanks.
Old Jun 19, 2010 | 09:32 AM
SniperHunter's Avatar
SniperHunter
I have this too, but I'm pretty sure it's normal. It's been that way since the car was new.
Old Jun 19, 2010 | 09:40 AM
aDDandrew's Avatar
aDDandrew
is your car rolling when you're putting it in drive?
Old Jun 19, 2010 | 10:13 AM
sjthegreat1
no it does not roll
Old Jun 19, 2010 | 10:34 AM
raycs7's Avatar
raycs7
I have 03 coupe 95k, 04ZR 18k, 06ZR 37k, and G coupe 77k, all auto with no such issue..
Old Jun 19, 2010 | 10:55 AM
GeauxLadyZ's Avatar
GeauxLadyZ
I dont have this issue, either. 05' auto.
You check your trans fluid lately? How long since a full flush?
Old Jun 19, 2010 | 11:06 AM
Beast101's Avatar
Beast101
Default +1
Mine does that. Works fine though.
sjthegreat1
I just changed the tranny fluid when i did the transgo valve body just recently about 1,000 miles ago
Old Jun 19, 2010 | 02:27 PM
winchman's Avatar
winchman
Mine doesn't do it.
Old Jun 19, 2010 | 04:56 PM
ImWeeZzel's Avatar
ImWeeZzel
mine doesnt do it+1
im not an AT expert, but you should check/change the fluid/flush completely.
You know how the transmission pan has 2(if im not mistaken) magnets on the inside, look for metal shavings. my older bro had a grinding noise in his silverado from P-R. we drained the fluid, surely enough there were metail bits that came out too. 6months later his tranmission went out. I hope this doesnt happen to you. I could be completely wrong. In your case I hope I am.
Old Jun 20, 2010 | 09:21 AM
adamciya350's Avatar
adamciya350
Are you on an incline when this happens?
Old Jun 20, 2010 | 10:33 AM
winchman's Avatar
winchman
When parking on an incline, I always engage the parking brake and let off the foot brake BEFORE I shift into park and shut the engine off. That way there's no load on the transmission park pawl. When I'm ready to go again, the parking brake stays on until I've shifted the transmission out of park.
That's probably covered in Driver's Ed. Or should be.
Old Jun 20, 2010 | 04:22 PM
Accordaleer's Avatar
Accordaleer
I only hear anything if parked on an incline, which is everyday but I usually do what winch said.
Old Jun 20, 2010 | 07:16 PM
exZilaration's Avatar
exZilaration
Was it grinding before the trans go kit? Maybe that with a combination of low tranny fluid might be the culprit
Old Jun 20, 2010 | 08:24 PM
dirtbikr's Avatar
dirtbikr
If you keep your foot on the brake and hold it tight until it completely engages reverse, it shouldn't make the noise. Mine has the same thing, and since I go from D --> N and pause there, then take my foot off the brake, and then push the button in and go to reverse without putting my foot on the brake, I hear it too. But when I keep my foot firmly on the brake I don't get it. It does sound worrisome when it does it, but I'm convinced it's fairly normal, mine's been doing it since new and it has 50k on it now...
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
