Rough shifts after VB change on 5AT
Old Jun 30, 2010 | 11:56 PM
Minda's Avatar
Minda
Question Rough shifts after VB change on 5AT
After a drift session that I had last winter VB on my 5AT died (stuck in Safe Mode 4th gear). It took some time to figure out what is wrong and some further time to get a replacement VB.
I swapped it for the replacement VB and now I have these realy rough shifts 1-to-2 and 2-to-3. The car kind of jumps forward and the rear end looses traction for a part of a second.
Also, at full throttle it would bounce several times off redline before shifting into higher. No fun at all .
ATF is brand new Nissan Matic and filled to norm.
The new VB came from a scrapyard, hence I am guessing incompatibilities with the ECU (I've heard some different versions exist)?
Any other ideas would be much appreciated.
Old Jul 1, 2010 | 02:03 AM
350Zdj's Avatar
350Zdj
Get the GTM VB upgrade bro.
Old Jul 1, 2010 | 03:15 AM
Minda's Avatar
Minda
I am not sure that it'll help, if there is some underlying problem.
The replacement VB although from a scarpyard is basically new (car had less than 5k miles). Forgot, to mention that mine is 04 5AT (internal TCM) with ~40k miles.
Old Jul 1, 2010 | 03:48 AM
adamciya350's Avatar
adamciya350
+1
Old Jul 3, 2010 | 04:34 PM
SexyRob's Avatar
SexyRob
did you get the new valvebody reprogrammed to your car? heard only dealers can do this since there is some info associated with the transmission and your VB
Old Jul 4, 2010 | 02:58 AM
Minda's Avatar
Minda
I did not. And it leaves me guessing whether indeed some reprogramming is needed. Can somebody confirm or deny this, please?
Old Jul 5, 2010 | 03:46 PM
2000atlanticgt's Avatar
2000atlanticgt
Your car is an 04 5AT, but what year/model did the VB and TCM come from?
Old Jul 6, 2010 | 01:31 PM
Minda's Avatar
Minda
It came from 05 5AT.
Old Jul 13, 2010 | 10:03 AM
2000atlanticgt
VB part numbers from 04, 04.5, and 05 are all different in the Nissan parts system. I suspect you need to find a VB specifically for your car for it to work properly. Check your PMs.
sherm
Apr 11, 2020 05:21 PM
ablaine
Nov 29, 2016 10:13 AM
