Consult 2 didnt work......what next?
Old Jul 5, 2010 | 06:50 PM
BristishZ's Avatar
BristishZ
Default Consult 2 didnt work......what next?
okay guys. after installing a new light weight flywheel and clutch my car has been having problems idling. I took it to jackie cooper imports which is a nissan/infiniti dealer and they rest the idle air volume mix. that didnt work. it idles fine when cold, but when ever hot and you push in on th cluth, the idle dips really low, comes back up, goes down again and so on so on. its all over the place. i have no check engine lights and i havent messed with any of the sensors on the engine whil ei was doing the clutch install. apart from that it runs great! the machine at the dealer said that the self learn was working fine and it should relearn it, except it isnt. Any ideas or thought? and if i was to get it tuned with osiris, do you think it would be able to fix it? thanks Guys
Old Jul 5, 2010 | 07:42 PM
sdZ33's Avatar
sdZ33
How long ago did you do the clutch?
Old Jul 5, 2010 | 07:56 PM
INTIMAZY's Avatar
INTIMAZY
Crank angle sensor?
Old Jul 5, 2010 | 08:22 PM
BristishZ's Avatar
BristishZ
i have put about 500 miles on the clutch. and the car starts fine. apart from when its hot, you have to give it a little gas because it will stall out. doesnt matter whether you have the clutch out just after you started it or if you have it in. it will start...rev up... and then die. i could try a new crank angle but surly that would throw a code and or it wouldnt start very well. other than idle and starting it runs great whil edriving
Old Jul 6, 2010 | 05:17 AM
str8dum1's Avatar
str8dum1
are youe sure you put the flywheel on the correct mounting hole. there are 2 holes for the guides. one for front wheel drive and 1 for rear wheel drive.
I bet its not installed properly
Old Jul 6, 2010 | 05:39 AM
RandomHer0's Avatar
RandomHer0
Mine does that, did you get an idle bump?
Old Jul 6, 2010 | 07:23 AM
BristishZ's Avatar
BristishZ
no it is installed correctly. the transmission has been out like 6 times. the flywheel is deffiantly installed correctly, thats for sure. i havent had any kind of idle bump. is there anything that dictates what the idle should be or can i set it at what ever i want? i was thinking like 900 or 850.
Old Jul 6, 2010 | 07:28 AM
RandomHer0's Avatar
RandomHer0
bump till it stops lol.
900ish
I never fixed mine, I just got used to blipping the throttle or leaving the AC on for the idle bump
aarrgghh
May 1, 2022 11:04 AM
Darkspy
Sep 7, 2015 09:09 PM
jesseenglish
Nov 14, 2003 07:43 PM
MR RIZK
Oct 14, 2003 08:56 AM
ksj
May 7, 2003 06:49 PM
