Should I send back to get replaced
I just got the JWT clutch/fly combo delivered, and I have no intentions of flaming a company in any way what so ever because the problem most likely occured in transit via fed ex, but there is a little scuff to the back side of the flywheel, and I am extremely ill informed on such matters, will there be any issues/premature wear do to this and should i send it back to get replaced?
Pictures included:
Pictures included:
you might get screwed if you signed the waybill stating youve received it in good order. you should check the package to see if its damaged before signing it.
if there was no visible damage to the box, then you can go after the vendor for not packaging the product correctly. either way, yuo might be able to get a credit to have that machined locally
The teeth on the outside of the flywheel are the starter ring gear. Section EC of the service manual says the position sensor uses a signal plate.
To generate the pulse pattern shown in the manual, the signal plate will have twenty seven notches arranged in three groups of nine each. The outer edge will be smooth between the groups, and there will be enough space for three more notches in the smooth part. The starter ring gear has too many teeth to generate the signal pattern shown.
Can you post a picture of the entire flywheel showing all the notches? Or just count them and describe the pattern?
You may be able to get them to send you a new signal plate to replace the damaged one. I'd suspect the screws that secure it are installed with Loctite, so you might want to see if you can get them all loose before you agree to do the swap yourself. They'll be able to tell you.
Although it SHOULD be fine, I would still ask for a replacement. You wouldn't want to have to remove the trans a second time if it ends up messing with the crank pos sensor.
lolwatbro
Oct 9, 2021 04:58 AM
Vigman
Nov 17, 2015 04:34 AM
