Coilpack Wireharness connection order
Old Jul 19, 2010 | 08:52 AM
eyeSea's Avatar
eyeSea
Default Coilpack Wireharness connection order
I checked all over the service manual but couldn't find a diagram for this.
So while changing my plugs on the driver's side bank, I was getting carried away and instead of replacing 1 plug at a time. I decided to do them all instead of 1 at a time.
After all the plugs were changed and coil packs installed, I started to connect the wire connectors for each coil pack, when I realized... the connector for cyl 4 and 6 could reach each other.
I did what made sense and connected the coil packs from the end of the harness 1 at a time back.
(i.e. I connected the first connector at the end of the harness to Cyl 2, then 4, then 6).
Can anyone confirm this? I only ask because after my plug change, on the first start the Z started to misfire and then backfire.
Thanks!
Old Jul 19, 2010 | 11:57 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
If you pull back the wire cover a bit, #4 coil should have a gray wire, #6 will have a gray/red wire.
edit: this is assuming you have a DE engine
Old Jul 19, 2010 | 12:33 PM
winchman's Avatar
winchman
Yep, the wire color coding is show in the diagram for the ignition signal in section EC of the service manual. For 2007, it's on page EC-703.
Old Jul 20, 2010 | 10:00 AM
eyeSea's Avatar
eyeSea
Yeap, that did the trick. Thanks guys!
Old Apr 1, 2013 | 09:14 PM
blAk mAx's Avatar
blAk mAx
pic?
Old Oct 3, 2014 | 10:49 AM
Lotekkid666's Avatar
Lotekkid666
Default worried about sputtering
had a cylinder 2 misfire and replaced the coil pack and ran great but now i have a slight sputter. where can i look for a diagram? I have a 2003z.
Old Oct 3, 2014 | 10:59 AM
eyeSea's Avatar
eyeSea
I can't find a diagram now, but iirc, this is how it goes:
- Terminated end of harness connector goes to Cyl 2
- Middle connector goes to Cyl 6
- Closest to firewall connector goes to Cyl 4
My mistake in 2010 was connecting them in order which is what caused my misfire issues.
Along with this post, I'd like to update that Cyl 6 coil pack has died 2 times since I've owned this car. The first replacement coil was non-oem from ebay brand new. That lasted about 2 years. It died and was again replaced, but with a used oem pack from a G35. I'm happily running on this pack for 2+ years.
Old Oct 3, 2014 | 11:15 AM
Lotekkid666
Going to check it tonight and will get back to let you know how it goes, Have you checked your capacitor?
Old Oct 5, 2014 | 02:21 PM
Lotekkid666
Default Fixed it!!
I checked my spark plug gap and the gaps were all too wide, all coil pack harnesses were in the right places. Is the capacitor supposed to have like a Caramel colored grease inside and on the two prongs?
Old Jun 29, 2020 | 07:48 PM
jv350z's Avatar
jv350z
Good info here
Old Jul 11, 2020 | 12:37 PM
rhd350's Avatar
rhd350
Default Coil pack Connectors! PLEASE HELP
I know this is an old thread but I did the same thing he did and took them all out at once. So this helped me out a lot!! Just curious if anyone knows the colours for the 4 other connectors
Old Apr 5, 2021 | 09:51 AM
genogunn's Avatar
genogunn
Default Harness order
[QUOTE=rhd350;11029085]I know this is an old thread but I did the same thing he did and took them all out at once. So this helped me out a lot!! Just curious if anyone knows the colours for the 4 other connectors. This helped me out . I did the saw thing. When I took mine down it was snowing out, and even though I marked and taped everything, moisture got inside and my marks and smudged, so you couldn’t read the numbers anymore. When I hooked up #2, I saw I couldn’t read the 4 and 6 any more.The wire is pretty close in length and it looked like I had them pointed to the right plugs on my harness.Nope , I had 4 on 6 and 6 on 4. I’m great full for this forum.
Old Jul 6, 2025 | 03:13 PM
MPort88's Avatar
MPort88
Sorry to dig up an old thread but this saved my *** today. Like the others before me, went to do plugs and coils and got over-zealous and removed all the coils and coil harness bracket bolts at once and then lost track when reassembling. Luckily it was Bank 2 so the grey and grey/red matched up perfectly 🙏🏽 TY!
I DTW I
Jul 12, 2023 03:48 AM
Hayden Winborn
Mar 21, 2017 10:20 AM
Redefin3d
Apr 20, 2013 01:13 PM
Merck
Feb 5, 2009 05:45 AM
shift_6x
May 24, 2004 03:52 PM
