CJM Fuel Return System... Need help missing parts!!
Old Aug 7, 2010 | 07:32 PM
zcar03's Avatar
zcar03
Default CJM Fuel Return System... Need help missing parts!!
I bought this used CJM system and I know Im missing the fuel correction line http://www.cj-motorsports.com/catrck.htm but am wondering if anyone out there knows what else I need. It looks like I have some extra lines here too. Id like to do the CJM stage 2 it seems like all I need is a large return line but Im unsure. Any help would be great. Thanks
Attached Thumbnails CJM Fuel Return System... Need help missing parts!!-1cjm.jpg   CJM Fuel Return System... Need help missing parts!!-2cjm.jpg   CJM Fuel Return System... Need help missing parts!!-3cjm.jpg   CJM Fuel Return System... Need help missing parts!!-4cjm.jpg   CJM Fuel Return System... Need help missing parts!!-5cjm.jpg
Old Aug 7, 2010 | 07:33 PM
zcar03's Avatar
zcar03
More
Attached Thumbnails CJM Fuel Return System... Need help missing parts!!-6cjm.jpg   CJM Fuel Return System... Need help missing parts!!-7cjm.jpg
Old Aug 7, 2010 | 08:21 PM
xzotklr's Avatar
xzotklr
Go to the source. Charles @ CJM will be able to help you. CALL HIM!!!!!
Old Aug 7, 2010 | 08:37 PM
binder's Avatar
binder
the stage 2 will have a 1/2" hardline pressure side along with the attachment for the stock pump to a SS line then that goes to a large hardline.
Looks like you have a stage 1 so far.
I have a stock basket with the return correction already installed in it. basket is modified with a walbro in it. PM me if you are interested. I have that and the rear rail adapter for a cjm stage 0 since i have a twin pump.
Old Aug 8, 2010 | 04:18 AM
zcar03's Avatar
zcar03
They dont have a phone number anymore...
Old Aug 8, 2010 | 08:04 AM
binder's Avatar
binder
that's charles' number he has in his signature. I contact him on it.
Old Aug 9, 2010 | 07:18 PM
zcar03's Avatar
zcar03
Thanks Ill call him tomorrow I need the 3 parts that allow me to attach to the OEM fuel hardline see in step 5 here
http://www.cj-motorsports.com/s1install.htm
Old Aug 10, 2010 | 05:18 PM
binder's Avatar
binder
ya, you'll need hardpipe adapter or order the 1/2" upgraded hardpipe with lines. That will give you most flow if you are planning on maxing out a walbro.
Old Aug 10, 2010 | 06:29 PM
zcar03's Avatar
zcar03
Can I just get a large AN hose and run it straight to my fuel pump?
Old Aug 11, 2010 | 09:53 AM
binder's Avatar
binder
yes. I would run no less than an 8AN since you will be feeding that line with 2 6an's.
You could also run dual 6an's if you want and put each pump on a rail (theoretically). Not sure how variances in each pump would affect the a/f of each bank though.
Old Aug 11, 2010 | 08:22 PM
zcar03's Avatar
zcar03
So this is what Im thinking instead of tapping the 8AN hose into my OEM hardline, I can attach a long 8AN hose to the heatwrapped one that comes with the kit. Run this hose straight to my fuel pump and ditch the OEM hardline. The task is how do I then attach this 8AN hose to My OEM out port on the fuel pump. I think A hose goes over the fuel pump out port. Should I attach a male AN to barb fitting to the 8AN line and then a hose from the out on the pump to the barb on the 8AN?
Old Aug 12, 2010 | 10:31 AM
binder's Avatar
binder
Charles sells a special fitting that attaches to the oem plastic nipple and then has an AN fitting on it. You could use an 8an fitting on that piece then run the 8an hose up to the front, use an 8an to 8an adapter to the heat coated piece and you're done.
that piece. It's in the 350z catalog as a fuel pump fitting. You'll probably have to ask him to include an 8an because i think it normally comes with a 6an line.
Old Aug 12, 2010 | 01:20 PM
zcar03's Avatar
zcar03
charles sells a special fitting that attaches to the oem plastic nipple and then has an an fitting on it. You could use an 8an fitting on that piece then run the 8an hose up to the front, use an 8an to 8an adapter to the heat coated piece and you're done.
awesome! Thanks
_bit
Oct 2, 2015 07:49 AM
