Aftermarket Oil Pressure Sensor position
Old Aug 22, 2010 | 06:42 AM
XM 1's Avatar
Default Aftermarket Oil Pressure Sensor position
i want to add an extra oil pressure sensor behind my arc oil cooler (just to make sure everything works fine ). i have a greddy informeter and want to use the available sensor, but i´m not sure how the position of it should be.
this is a quick reference of what the sensor looks like.
my question now is should it be mounted as shown on the pic or just upside down??? or is it equal
Old Aug 22, 2010 | 07:25 AM
citymunky's Avatar
citymunky
Old Aug 22, 2010 | 07:59 AM
Blck350z's Avatar
Blck350z
XM 1: I do not think it matters how you position your sensor. As citymunky posted, I used the Greddy sandwich plate to mount my STRI oil: temp & pres. sensors. As you stated though you have an ARC oil cooler, if that uses a sandwich plate already I do not know if you can add another one onto that (for a total of 2 sandwich plates). I was also thinking of adding an oil cooler but can into this same problem. I was thinking of tapping my oil block for the sensors.
Lets see some more replies!!!
Old Aug 24, 2010 | 08:46 AM
rcdash's Avatar
rcdash
I use a Greddy adapter for temp and pressure sensor ports and a Mocal for the oil cooler. Try to fit the sensor BEFORE installing. I think I had to tap for NPT threads (come with BSP).
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
