230kw 350z how strong?
Old Aug 30, 2010 | 04:05 AM
GERRY#1's Avatar
GERRY#1
Question 230kw 350z how strong?
How strong is the 230kw motor vs the 206kw motor? Hard driving, trackday...! Both in standard form. Motorwise?
Last edited by GERRY#1; Aug 30, 2010 at 04:15 AM. Reason: not explain myself correctly
Old Aug 30, 2010 | 04:07 AM
dmroberson's Avatar
dmroberson
24kw stronger?
Don't really understand the question
Old Aug 30, 2010 | 06:37 AM
FineWine's Avatar
FineWine
The 206kw motor makes less power than the 230kw motor, but the 230kw motor is stronger.
Old Aug 30, 2010 | 07:54 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
I think he's referring to the HR vs. DE in regards to the metric system of power? Just a guess...
Old Aug 30, 2010 | 08:04 AM
FineWine's Avatar
FineWine
correct, but what is the question? Which motor is stronger? The answer is in his post.
Old Aug 30, 2010 | 08:21 AM
GERRY#1's Avatar
GERRY#1
Question
Which motor the DE or HR is going to take more track abuse?
Old Aug 30, 2010 | 08:36 AM
Flo-ridaZ33
ummm I'd say about the same... I havent really heard of reliability issues on either. If you plan on doing bolt ons... the DE isnt that bad of an option. If you choose to keep it stock.. the HR is considerably better.
Old Aug 30, 2010 | 09:16 AM
One has 26 more KW than the other whatever a kw is.
Old Aug 30, 2010 | 09:44 AM
xzotklr's Avatar
xzotklr
kw= kilowatt
Old Aug 30, 2010 | 10:16 AM
GERRY#1's Avatar
GERRY#1
OK. I have a 2004 std 350Z and a 2006 non rev up with a S/C and some goodies pushing out 282rwkw and 450nm. I want to buy a new spec 350Z with the HR motor and keep it stock for trackday's only. So my question is to find out which one is going to (motor) take the abuse better, standard DE or standard HR? 1kw= 1.34hp for those of you that don't know.
Old Aug 30, 2010 | 11:10 AM
FineWine's Avatar
FineWine
https://my350z.com/forum/2003-2009-n...-question.html
Old Aug 30, 2010 | 02:37 PM
Nathan's Avatar
Nathan
The HR has beefier rods & higher spec rod bolts.
Also the oil pump while not pumping any more oil or a higher pressure has the vane material made from a better grade of steel. There were some reported oil pump internal problems with the DE pump at high RPM's (way above the rev limit)
So to answer your question, if the motor is to be run stock both motors can take abuse if kept at the redline but due to the higher red line on the HR there is more margin for driver error in the cut & thrust conditions of a trackday.
Old Aug 31, 2010 | 12:33 PM
GERRY#1's Avatar
GERRY#1
Thumbs up
Thanks Nathan.
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
