Power steering cooler installed
Old Sep 10, 2010 | 03:26 PM
JDMStanced's Avatar
JDMStanced
Default Power steering cooler installed
I thought this PS cooler installation would be easy but it took me some time lol.
Since my autozone cooler is bigger than the stock one, the two hoses fit there really tight.
The lower hose fit there ok but the top one has to make a U shape to fit there..so the hardline is LOWER than the cooler connector. I heard something that the hard line has to be on higher than where it connects to because of gravity or whatever.. Am i fine with the hard line and the hose being LOWER than where it connects to, and the fact that my line makes a U shape ?
I attached pics, you'll see what i mean.
Attached Thumbnails Power steering cooler installed-img_0491.jpg   Power steering cooler installed-img_0490.jpg
Old Sep 10, 2010 | 06:55 PM
JDMStanced's Avatar
JDMStanced
no one?
Old Sep 10, 2010 | 07:01 PM
winchman's Avatar
winchman
I'd suggest getting a U-bend from a place that sells parts for air conditioning equipment. You could also make one from elbows soldered together. The hose won't last long with that sort of kink if it gets hot.
Old Sep 10, 2010 | 07:08 PM
Rubidium's Avatar
Rubidium
I wouldn't think it matter too much as long as the pipe that doesn't get crimped.
Old Sep 10, 2010 | 07:17 PM
JDMStanced's Avatar
JDMStanced
The fact that the fluid in the hose has to shoot upward, not downward, would it cause any delay or something like that?
This PS cooler looks shiny through the bumper lol But i hate that the cooler is tilted!!
Old Sep 10, 2010 | 07:26 PM
JDMStanced's Avatar
JDMStanced
Damn it's tilted too much. See how nasty the stock PS looks haha
The third pic shows the bottom of the cooler.There's like 1inch gap between the cooler and the bracket that i made with my old license plate lol.
Attached Thumbnails Power steering cooler installed-img_0489.jpg   Power steering cooler installed-img_0492.jpg   Power steering cooler installed-img_0493.jpg
Old Sep 13, 2010 | 11:23 PM
bbs350z's Avatar
bbs350z
you made a bracket with a license plate? subscribed...
Old Sep 14, 2010 | 02:39 AM
winchman's Avatar
winchman
Maybe he means "out of" instead of "with".
Old Sep 14, 2010 | 03:55 AM
JasonZ-YA's Avatar
JasonZ-YA
hey, not a bad attempt but dont reuse that section of hose...you used the old oem hose coming off the line that has the bend in it right??
just remove that section of hose and buy about a few feet of basic heater hose from autozone that doesn't have any preformed bend in it and route it as you need to that top connection.
the bend is whats tilting your entire cooler at an angle....
-J
Old Sep 14, 2010 | 03:57 AM
JasonZ-YA's Avatar
JasonZ-YA
OR
you can even buy more section of hose and connect to the new section you buy with one of these:
OR
go back to the next section of hardline back behind the core support and connect straight to that...
-J
Old Sep 14, 2010 | 04:08 AM
JasonZ-YA's Avatar
JasonZ-YA
Here, this is what i mean!
go buy a single long hose, i would guess about 3 feet would be more than enough (measure just in case) and connect it to this second hardline back behind the core support and run it to the new larger cooler you bought.
you can do this to both lines if you want, but it seems as if your top line is the only one giving you problems...
SEE HERE:
-J
Old Sep 14, 2010 | 04:31 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
Jay... I think thats his best option and makes more sense now that I saw the illustration. Thank God for pictures.
Old Sep 14, 2010 | 05:07 AM
JasonZ-YA's Avatar
JasonZ-YA
^ ya, its quite easy....
OP, your gonna love having this larger cooler..........makes the PS system work top notch all day at an event....
-J
Old Sep 14, 2010 | 07:43 AM
JDMStanced's Avatar
JDMStanced
SEE HERE:
-J
why didn't I think bout this lol. I guess I wanted to keep the hardline lol
Old Sep 14, 2010 | 07:44 AM
JDMStanced's Avatar
JDMStanced
yh I meant out of instead of with
Old Sep 14, 2010 | 07:53 AM
JDMStanced's Avatar
JDMStanced
-J
edit: the right side of the cooler is tilted toward the radiator, not just tilted up n down.
I don't think it wouldbe really necessary to change it because I don't have a problem yet.
now that I think bout the tilt, it's really good for airflow. the air comming from the front side, as it hits the cooler, the air is lead to radiator. not just the cooler sucking allthe air. because my bracket is skinny, it lightly swings back n forth as the car moves. good for air flowing
Old Sep 14, 2010 | 09:34 AM
Deedilus's Avatar
Deedilus
That's weird, that didn't happen with mine when I did it. Excellent bang for the buck mod too.
Old Sep 14, 2010 | 04:56 PM
Flo-ridaZ33
Lol... I wonder if you could do a V-mount style on the Power steering cooler?
Old Sep 14, 2010 | 05:16 PM
JDMStanced's Avatar
JDMStanced
that's exactly what I thought. I saw v mount intercooler set up on genesis. I wish 350z has that kinda set up
Old Sep 14, 2010 | 05:31 PM
Flo-ridaZ33
I'm going to install my Stillen Oil cooler and a larger power steering cooler when I return in country... so this was thread was pretty informative. I wonder what benefit the PS cooler would have if was tilted back a little?
