The WTF noise thread
Old Sep 14, 2010 | 05:10 AM
djamps's Avatar
djamps
Default The WTF noise thread
Repost from Driver. Issue is currently unresolved.
So, WTF is that noise right after shutdown, then 30sec later at the end?
Aside from needing an exorcist, I'm guessing some kind of freakish back current through the throttle body.
http://www.youtube.com/watch?v=5uo4J...layer_embedded
Old Sep 14, 2010 | 05:30 AM
osiris79's Avatar
osiris79
i just got the same feeling I had while watching the Exorcist for the first time. Sorry to not be any help.
Old Sep 14, 2010 | 06:45 AM
superchargedg's Avatar
superchargedg
Damn Noobs
WTF?
Old Sep 14, 2010 | 07:03 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
LMAO!
I have no suggestions - specially since its AFTER the car is off for 20-30 seconds..
Old Sep 14, 2010 | 08:33 AM
winchman's Avatar
winchman
Vacuum canister for power brakes bleeding down because of leaking check valve? See if the brake pedal is unusually hard when the engine is off after the noise happens. That would verify the lack of vacuum in the canister. It should store enough for a couple applications of the brake for quite a while after the engine is off.
Old Sep 14, 2010 | 09:37 AM
Deedilus's Avatar
Deedilus
LMFAO what the hell! I think you do need an exorcism, there's gonna be some dead being stuck in your plenum or something of that nature. Sorry to be no help, but damn I wasn't expecting that!!! Haha
Old Sep 14, 2010 | 09:43 AM
350ZTheStandard's Avatar
350ZTheStandard
Have you checked the air pressure in your tires???
Old Sep 14, 2010 | 10:02 AM
TheFarmer's Avatar
TheFarmer
lol
Old Sep 14, 2010 | 10:04 AM
midz350's Avatar
midz350
I'm dying over here lool
Old Sep 14, 2010 | 10:58 AM
Z_flip's Avatar
Z_flip
i iz scurred now
Old Sep 15, 2010 | 11:56 AM
winchman's Avatar
winchman
Maybe it's something to do with the air conditioning. Does having the AC (and defrost) off make any difference?
Old Sep 15, 2010 | 12:02 PM
zer0cool's Avatar
zer0cool
lmao wtf ahahahah dude sell that thing asap...
Old Sep 15, 2010 | 01:14 PM
onagao's Avatar
onagao
DUDE. YOU NEED TO SELL THAT WITHIN 7 DAYS! I'm pretty sure I've seen a movie about this sh*t.
Old Sep 15, 2010 | 07:36 PM
winchman's Avatar
winchman
Hey, OP.
I've given you two semi-reasonable possibilities with easy tests to see if they're the cause. How about some feedback?
Old Sep 16, 2010 | 05:55 AM
djamps's Avatar
djamps
It's not my car. I just reposted it from driver. I did forward the ideas to him, here are the results, at least based on the testing ideas:
It's not the brake system.
Not the A/C either.
My suggestion, to rule out the TB, is to remove the air filter and cover the pipe after shutting it down to see if that mutes the sound. I still think it's coming from the TB...electrically induced noises from the throttle plate perhaps. The throttle body stays energized for around 30 seconds after shutdown (and the entire ECU). Listen carefully, you can hear some pops/clicks that do not sound pneumatic just after shutdown, and again before the 'screech'.
Old Sep 16, 2010 | 10:20 AM
thatv35guy's Avatar
thatv35guy
LOL, time for an exorcism!
Old Sep 16, 2010 | 10:28 AM
ashtrojan2008's Avatar
ashtrojan2008
she's crying for boost!
Old Sep 16, 2010 | 04:40 PM
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
those first couple clickes are the TB i wouldnt say "reseting" istelf but it opens and closes a couple times after it shuts down.
and the other noise means your ****ed.
Old Sep 16, 2010 | 04:46 PM
0jiggy0's Avatar
0jiggy0
Thats one of the craziest things ive ever seen.
Old Sep 18, 2010 | 10:37 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
I have seen Cooling system do this, Replicate the noise and pay attention to the cooling system hoses and rad cap, you will see that 's where it is coming from .
Good luck
Sam
