Sikky 350z/G35 LSX swap
Damn, you're younger than I thought you were, too.
Don't worry, there are plenty who are older than you, although most of the current members are probably in their 20s and also 30s.
I have a question about the headers, specifically the ones with 1-7/8" primaries. What sort of outlet flange do they have or does the user have to weld one on? What size is the outlet, I would assume 3"? Also how many O2 sensors are on them? Can I fit the OEM and a wideband or will I have to install the second bung myself?
These would all be good things to have on your website....just my $0.02
so far on my list I got
Sikky headers ( 7/8 )
custom 3" exhaust
L92 heads ported and polished
cam (undecided)
springs
ARP headstuds
FAST 102 w/ TB
Injectors
walbro
fuel rails.
+ TUNE
Shooting for 500+ NA
... The beauty about the LS motors is that the parts are cheap!!!.. you can get killer heads for 1000-1200 and they breathe like hell!
very nice! i gotta search up for a good cam... i cant wait for the fast 102.. and tb... how are you controlling the TB? electronic or cable?
custom 3" exhaust
cam (undecided)
springs
ARP headstuds
FAST 102 w/ TB
Injectors
walbro
fuel rails.
+ TUNE
custom 3" exhaust
cam (undecided)
springs
ARP headstuds
FAST 102 w/ TB
Injectors
walbro
fuel rails.
+ TUNE
That's interesting they would sell a coated header that needs welding done on it. Kind of defeats the point.
custom 3" exhaust
cam (undecided)
springs
ARP headstuds
FAST 102 w/ TB
Injectors
walbro
fuel rails.
+ TUNE
custom 3" exhaust
cam (undecided)
springs
ARP headstuds
FAST 102 w/ TB
Injectors
walbro
fuel rails.
+ TUNE
Vas_Z33,,
Nice we are doing about the same thing, in engine mods.. I am controlling the TB via Cable.. with a GTO pedal assembly. I am going to do a lot of drifting in this so I also got a KRC drift Power Steering pump, looks so good..
well it all depends.. I would say 10K+... but I got a good deal on my motor and t56... with only 25k miles.. and im using my FI currently in the Z as well as the motor and 009 transmission to fund my project.. so in my case its different.
I have about everything needed to do this swap except the Sikky kit(~$4K), which I'll be ordering next week or the week after and I'm also getting HP Tuners VCM Pro Suite ($650) to tune it and I'm at just under $11K with L92 #823 heads & L92/LS3 intake manifold, as well as a brand new T56 Magnum(2.66 gear set).
All said and done I'll have about $16k invested and I'm going to rebuild the L92 heads and mill them about 0.015" which will run about another $1500-2000. But I should put down 450-480whp @ 6500-7000 rpms, according to the cam I've selected with the help of Comp Cams (LSR 293LR HR14).
. Im getting the fast102 and electronic TB for about 1200 shipped! complete plug and play for the ls2 or 06+ GTO/VETTE.I have about everything needed to do this swap except the Sikky kit(~$4K), which I'll be ordering next week or the week after and I'm also getting HP Tuners VCM Pro Suite ($650) to tune it and I'm at just under $11K with L92 #823 heads & L92/LS3 intake manifold, as well as a brand new T56 Magnum(2.66 gear set).
ah very nice! cable would be better in your case then
definitely get the L92 heads ported! they bond very well with the ls2.. I did find this other site where they sell completely brand new racing heads ( 8000rpm ) for about 1700... Ill see if i can find the link.. I may end up going that route if there worth it
. Im getting the fast102 and electronic TB for about 1200 shipped! complete plug and play for the ls2 or 06+ GTO/VETTE.definitely get the L92 heads ported! they bond very well with the ls2.. I did find this other site where they sell completely brand new racing heads ( 8000rpm ) for about 1700... Ill see if i can find the link.. I may end up going that route if there worth it
alone there 1000... but figure with everything around 1800.. they assemble it in house and sent you the heads to bolt in.
but then again, if you shop around you can get some good l92s ported for cheap as hell
http://www.lingenfelter.com/mm5/merc...egory_Code=C40
Guys keep in mind if you run the e40 ecu (ls2 drive by wire), it won't let you run anything larger than a 60lb injector. You have to change other maps to run larger ones. Snyper ran into that with his ls2 turbo and found a way around it
