Sikky 350z/G35 LSX swap
Old Apr 28, 2011 | 10:01 AM
  #301
Armed Ferret's Avatar
Armed Ferret
Originally Posted by Royal_T
Yeah cause that does not sound right
kit is like $2,250 + $650 for headers and I think its $500 for intake.. So no where near 12k
Plus engine, plus transmission, plus clutch, plus engine management/dyno tune, plus all the little bits here and there (radiator, hoses, belts, fluids, etc.) that add up but nobody thinks about at first (hell I know I didn't).
Not to mention any supporting mods. Hell, the engine's out of the car, might as well slap on a few things while it's super easy. Cam, maybe heads, maybe underdrive pulleys, etc....
Oh and at least a custom mid-pipe, possibly full exhaust, since the headers definitely won't mate up directly (nor should they). High-flow cats are a good 500-600 bucks or so for quality pieces.
It all adds up.
Old Apr 28, 2011 | 01:40 PM
  #302
bigcloud's Avatar
bigcloud
Originally Posted by 2004Black350z
iv received prices just for a LS1 swap with the Sikky kit headers custom intake etc from 12-15k. I guess me seeing that has made me change my mind. i think ill just find me a used vortech.
With the vortech you're still lowering your reliability of your motor. Granted there have been stock block vortech builds that lasted a long time, but are you willing to take that chance?? Or would you rather have the N/A reliability of a V8 motor that you can beat the pi$$ out of and not worry about anything??
Old Apr 28, 2011 | 02:29 PM
  #303
Quamen's Avatar
Quamen
It all adds up.
Bingo! The initial hard goods are only about 75-80% the overall cost.
Old Apr 28, 2011 | 05:53 PM
  #304
2004Black350z's Avatar
2004Black350z
Exhaust Whore
of course i want the V8 however MONEY wise not the best investment. used vortech plus install and safe tune would b around idk 5-6k.
Old Apr 28, 2011 | 06:19 PM
  #305
Havok_RLS2's Avatar
Havok_RLS2
It all adds up.
Thanks for dumbing it down for the slow ones.
Old Apr 28, 2011 | 06:29 PM
  #306
Havok_RLS2's Avatar
Havok_RLS2
Well yeah. Smaller, lighter, shorter, better steering ratio, better weight distribution....just the name of the game.
LS-swapped Z isn't nearly as common as a corvette though....and the insurance is a good sight cheaper most of the time too.
I too toyed with the whole "used vette vs. Z for LS swap" stuff, and the Z, for me, won out. Either will be tons of fun, no doubt about that. I'm too much of a petrol-head (as Clarkson would say) to just get a car and go.
Agree 100% - (We all know which route I took)
Old Apr 28, 2011 | 07:53 PM
  #307
bbs350z's Avatar
bbs350z
Originally Posted by Havok_RLS2
Agree 100%
"Done Right" if the key word in Colecatz's statement. Sure it theoretically can be done for 10k or less by someone competent doing all the work themselves. Unfortunately I know of no one competent or otherwise that been able to keep it at or under that 10K budget (please chime in if I'm wrong). Most of the guys doing this kinda of swap end up doing other supporting mods that end up inflating the cost of the swap before the first key is turned. Things like headers, intakes, heads, cams, turbos, exhaust systems, stronger clutch, lighten flywheels, and whatever hell else you can imagine people doing to an engines while it's out of the chassis all cost money but I'm sure you could get away with not doing some of those things... for now.
The truth is if you're going to half a$$ this kinda swap then whats the point really? I thinks we need to be a little realistic at least to the other readers and those considering this type of swap in the future. LS swap on a 10K budget may indeed be doable but I still wouldn't call it realistic.
FACT: Sikky make that best most complete swap kit you can buy on the market but even then it's not everything you'll need to complete a swap. Everything you need to get it in there but you'll need a bit more to git-r-dun.
FACT: Given the same mods a Vette with still out run and out turn your LS swapped Z.
also because the swap is so new, were going to be seeing alot more realistic budget builds like the 240sx guys are doing. this along with some creative ingenuity that ive seen from the swap crowds should yield some pretty impressive results, and i believe can realistically be right around 9-10k turnkey by the average diy'er. the reason why so many of our swaps cost alot is because were goin big or goin home. quamen developed his own kit, top notch and costly to say the least. his work is flawless!! (leg humping you ryan lol) and has been a great help along the way. but also guys like snyper who diy'd his entire setup (very impressed to say the least), and yourself (havok) have all taken quite a plunge in the aftermarket parts department. but were also not the kind of guys to leave anything stock. sooner or later were gonna find guys that want a easy swap, reliable 350-400+rwhp and limiting themselves to xxx amount.
Old Apr 28, 2011 | 07:58 PM
  #308
Royal_T's Avatar
Royal_T
Sorry misunderstood his statement. I thought he was just talking about the swap kit and headers..
I know what is involved in the swap...... trust me
It all adds up.
Old May 2, 2011 | 10:56 AM
  #309
Cass007's Avatar
Cass007
After losing my 5th fully built VQ I'm on this bandwagon. Waiting on an email back from Sikky on the required hardware. Wondering if someone has a solid list of all the ancillary parts that are needed to make this work.
Fuel system - check
Stand Alone ECU - check
Radiator - ???
I may be one of those funding a swap with sold off F/I components.
Old May 2, 2011 | 11:05 AM
  #310
midz350's Avatar
midz350
^^ GL.
Old May 2, 2011 | 11:15 AM
  #311
bbs350z's Avatar
bbs350z
Fuel system - check
Radiator - ???
cass, what standalone are you running? the gm ecu can handle a ton of power, and even compensates for boost. so it might be worth your while to sell it and run the oem ls ecu (the true t56 ls1 ecu has a blue port and a red port-should be on the actual ecu). also, if your doing a built setup i can help you out. im running a 00 ws6 ecu and a 2001 ws6 harness. 98 ls1 harness and ecu is the only harness/ecu combo that is different from the rest so stay away from those is my recommendation. also if you go ls2, the e40 ecu from the gto only reads max 60lb injectors, in which case youd have to change values in other maps to run a higher injector (snyper had done this with his setup-hes also running hp tuners as i am).
if your doing a new built block, and need to break it in, i have a set of stock injectors, and maf that i can give ya for no charge after im done breaking in my motor and go speed density. also, if you plan on going f/i run a 2-3 bar map sensor, i hear the cobal ss is a direct plug n play.
the sikky swap is complete, the only other sikky accessories youd need is there power steering line kit, and clutch slave kit, and fab your own intake/exhaust after the headers. there wiring solution combines your oem nissan engine harness, the ls engine harness, and your oem nissan accessory harness (the one on the passenger side. the only thing they do not have a solution to is the tach, but speedhut makes a setup that quamen, and snyper have fit in there oem cluster. it sits over the factory tach, so theres no cutting of that, it just requires trimming of the plastics on the inside.
any other questions feel free to ask!! btw cass where you located? also in regards to your radiator question, im running a koyo rad with the flexible mishimoto universal hoses and stock fans.
Old May 2, 2011 | 12:01 PM
  #312
bigcloud's Avatar
bigcloud
Fuel system - check
Radiator - ???
I'm sorry that you lost your fully built VQ. It was all of your troubles that caused me not to do a built TT setup. I hope that you can get a bada$$ LS2 setup going and enjoying your car to the fullest!! I know you do things big and I think your LS swap will be a pretty bada$$ one!! Can't wait to see what you do!!
Old May 2, 2011 | 01:48 PM
  #313
Cass007's Avatar
Cass007
bbs - most of your first paragraph went over my head... I need to familiarize with the terminology of the components.
I may start by just doing a swap to get it up and running and can always pull it out in the winter to add/change components like heads or cam. The wallet is a bit thin after motor number 5 and everything that goes into getting a new setup sorted out. Until the car runs for a year straight it gets no love.
I have a ViPEC EMS full stand alone. My tuner says it will run any LS no issues. Where did you guys go to source your new engines? I am located in southern PA, probably 45-60 minutes from SIKKY.
I have a Mishimoto radiator with factory fans. I was hoping to get setup for somewhere around ~480-500whp or something that roughly feels like 12lbs of boost. I'm going to have a ton of questions and expect to do most of the work myself, certainly pulling the VQ and installing the LS looks simple enough.
Old May 2, 2011 | 03:06 PM
  #314
andz33's Avatar
andz33
Bbs- did you splice together the ls1 and z harness?
Is the 98 harness more difficult to splice together? I'm actually using the 98harness/ecu on my swap.
Old May 2, 2011 | 10:52 PM
  #315
bbs350z's Avatar
bbs350z
yea the install is extremely simple, same as a vq, except that the driver side header has to go on after the motor is in. and youd be surprised how cheap and plentiful the ls stuff is!
should you do a built shortblock, i can toss you all of the stock stuff ill no longer need, at least to just get it running like stock to ensure theres no wiring problems, etc. also, i got my built motor on ls1tech.com from a guy who had it built at GCRE (my friend knows the owner of gcre so i took his word on there awesome work). to show you how much cheaper parts are, i picked up the motor for $3500 shipped complete with 0 miles, built head, and a custom grind cam. had arp everything, and some pretty reputable ls parts (comp cams, etc), which is cheaper than youd find any vq built to the same extent. the knowledge and possibilities of the ls series is awesome.
im sending mine to sikky because i hate wiring and ran out of patience with this car, and for $550 its an appetizing price. as far as the 98 setup, i just read that its harder to tune/setup, and that the groundpoints are different, and 98 everything has to stay 98, no interchanging with 99+harness or ecu. but i think because you have a complete 98 setup (harness/ecu) you should be fine. i think its just that the guys that have problems are trying to put 98 harness w/ a 99 ecu and vice versa, and the different ground points get annoying.
Old May 3, 2011 | 07:06 AM
  #316
GoJira33's Avatar
GoJira33
As a guy said previously about getting a vortec. I was going to go that route but if sell your stock vq motor and trans thats brings the cost down on your part. If you have alot of vq bolt ons like i do you can get the mount kit or close to that amount. My plan is drive my vq till after i purchase everything but mount kit then sell all VQ parts& get mount kit so your cars not down for an extended pd of time. A vortec in my op will never be as fun as the v8 (torque= fun)
V8 will be worth the wait
Old May 3, 2011 | 11:23 AM
  #317
Cass007's Avatar
Cass007
Lets talk transmissions for a second. What are the guys that are already building using? All the codes are like learning a foreign language. I've been lurking on the LS forum, but complete motors are hard to come by and finding a built package seems even harder as I have no knowledge of what components I am looking for
Also, if I want to keep a manual trans, do I keep my pedal assembly and just change clutch lines?
Old May 3, 2011 | 01:57 PM
  #318
bigcloud's Avatar
bigcloud
Cass guys that want to keep a manual just buy an LS1 or 2/T56 combo. Most people try to get the full pedal assembly to keep the drive by wire throttle body on the LS2. You could also convert your LS2 to drive by cable as well. For some LS1's they were cable driven which requires a modification of either your pedal assembly or use a GM pedal and cable assembly. For ease of installation if I were you I would just buy a GTO LS2 drop out complete with pedal assembly, accessories, and computer, and harness. You can't go wrong from there.
Old May 3, 2011 | 02:23 PM
  #319
Cass007's Avatar
Cass007
Just send a text to my tuner to see if the ViPEC can control the drive by wire function on the LS, it does it on my VQ (only vipec and motec will do this). Also asked him if this would allow the use of my stock tach as well.
Thanks for the advice on the motor and trans... that is what I need... spoon feed me like a noob
Wow... he got back to me while I was typing this. The Vipec will control the drive by wire on the LS. The tach signal not yet, getting clarification if it is in the works and checking on the pedal assembly swap too.
Old May 3, 2011 | 04:06 PM
  #320
Cass007's Avatar
Cass007
I can keep the 350 pedal and clutch assembly, ViPEC just made canbus available for the 350, but it doesn't have the math formulas added yet so that it interputs the engine signal and moves the tach the correct amount. Updates are frequent, so this may be available in the near future.
I was suprised to find out that I could still use many of the features it provides like launch control and flat shift as well as having two or three different maps, one for pump, 100 oct and c16.... very interesting.
