Sikky 350z/G35 LSX swap
Old Oct 26, 2011 | 01:03 PM
  #541
Cass007's Avatar
Cass007
Originally Posted by Fluid1
Thanks for the info Vas. As I get closer to that point I'm sure I'll be asking a lot of wiring questions.
We're definitely going with the LQ9.
Really looking forward to seeing numbers from this build and how it compares in both performance and cost. If possible can you find out the weight of the assembled block?
Old Oct 26, 2011 | 01:14 PM
  #542
Fluid1's Avatar
Fluid1
Absolutely. It will be heavy as **** with the iron block and forged internals, but I will certainly post all details of the build from start to finish.
I already know what kind of numbers we're going to hit lol
It may be heavier, but at 800 wheel, who cares.
Honestly the cost is already WAAAAY cheaper than anything I could have expected. Of course, we're just starting and who knows what hitches we'll come acoss, but it will be well documented for all.
Mad props to SOHO Motorsports here in Charlotte, NC. The guys there bend over backwards to do the right thing for the customer, 100% of the time. I'll never go anywhere else, with any of my vehicles, as long as they exist.
-edit- Cass, where do you live?
Old Oct 26, 2011 | 11:51 PM
  #543
jerryd87's Avatar
jerryd87
lq9 is roughly the same weight as an assembled gen 1 small block chevy long block with aluminum heads, expect right around 480-500 pounds for the longblock.
Old Nov 12, 2011 | 08:47 PM
  #544
2TH PWR's Avatar
2TH PWR
My dream would be to drop in an LSX, preferably all aluminum,
and mate it with an EMCO sequential race trans. Maybe one day.
http://www.youtube.com/watch?v=ipC8Ire-cNg
Old Nov 13, 2011 | 09:17 AM
  #545
Cass007's Avatar
Cass007
I'm in PA, an hour north of Baltimore.
That shifter in the video above looks and sounds like A$$. I want something that makes my car more streetable, not less. This would be great for the track, but too much for the street IMO.
Old Nov 13, 2011 | 11:04 AM
  #546
2TH PWR's Avatar
2TH PWR
To each their own..
If i dropped in an LS2, my goal would be to make it mostly a race car.
If I wanted streetable, I'd stick with a stock VQ.
Old Nov 13, 2011 | 11:27 AM
  #547
bbs350z's Avatar
bbs350z
wonder how much fab work would ave to be done to get that to work.... although i hear the tr6060 trans is a bit longer so itd be interesting if somebody came out with a sequential shirter similar to ikeyas for this application
Old Nov 13, 2011 | 01:08 PM
  #548
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Are you talking about the constant rattle? The vid comments said that the rattle was from the reverse lever and that it has been addressed after the video was shot.
Originally Posted by 2TH PWR
To each their own..
+1
Old Nov 14, 2011 | 04:00 AM
  #549
Cass007's Avatar
Cass007
Missed the comments about the shifter... still not for me.
Old Feb 20, 2012 | 11:50 PM
  #550
sh0rtys463's Avatar
sh0rtys463
Browsed through as much of this thread as I could and was unable to find if we can put a l92 in our cars. Is it possible?
Old Feb 21, 2012 | 04:29 AM
  #551
Cass007's Avatar
Cass007
Anything is possible, just maybe not practical.... the kits out there seem to be for the LS series exclusively. You should post in the LS forums to see if anyone has info if the mounting is the same.
Old Feb 21, 2012 | 04:34 AM
  #552
jerryd87's Avatar
jerryd87
mounting is exactly the same you might have hood clearance issues though as the truck engines have a much much taller intake, but if you can make it fit the truck intakes flow on par with aftermarket intakes, like i said its just a lot taller.
also im not sure on the engine management and what would be best for it, since the l92 has variable valve timing. i imagine the best bet would probably be to get the ecu out of the same car and just use hp tuners.
Old Feb 21, 2012 | 09:02 AM
  #553
Langdonious Rex's Avatar
Langdonious Rex
Yes. An L92 is just the truck version of an LS3.
Old Feb 21, 2012 | 09:46 AM
  #554
sh0rtys463's Avatar
sh0rtys463
Looks like I'm going to be keeping my out for a GTO LS2 dropout
Old Feb 21, 2012 | 11:55 AM
  #555
Cass007's Avatar
Cass007
That's what all the cool kids did
I found mine on ebay from LKQ and there was another large LS graveyard near Philly that I called and they called me back when they got one in.
Old Feb 21, 2012 | 12:24 PM
  #556
bbs350z's Avatar
bbs350z
i cant find a bare ls1 block for ****, not locally at least. even the iron ones are rare around these parts. wtf.
Old Feb 21, 2012 | 01:30 PM
  #557
jerryd87's Avatar
jerryd87
ls1 is starting to get rare its been what 8 years since it left production? by iron block do you mean the 5.3L lm7/l33/lm4/l59 or are you looking at 6.0L lq9/lq4? probably is going to be near impossible to find just a bare block but local junkyards should have tons of wrecked trucks with them. if your after the 5.3L then look into the smaller trucks. 6.0 can be found in the smaller or bigger trucks(and by smaller i mean like 1500 series and there suv counterparts they share a frame with.)
and honestly you will probably pay about the same pulling a engine from a truck yourself as it would cost to buy a bareblock from someone.
Old Feb 21, 2012 | 05:41 PM
  #558
bbs350z's Avatar
bbs350z
5.3 would work, i would just bore it to 5.7 specs. my block has a hairline crack in it so id want to swap all my built internals over to a new one. aluminum or iron, no care. but i wanna keep it 5.7 so i dont have to buy different sized pistons, and from my research, most ls1's cant be bored out much at all if theyre aluminum
Old Feb 21, 2012 | 10:24 PM
  #559
Langdonious Rex
Look for an LM4, L33, LH6, or LC9. They are GenIII and GenIV 5.3 aluminum blocks from trucks and SUVs. I think I saw an L33 the other day for $200. They are great budget blocks to work from. ERL prefers to use them as cores for their monster cube (454+ci) engines because of their strength (after a resleeve, of course). Punching one out to put your 5.7 rotating assembly is going to require a resleeve which brings the cost up significantly. After you find an LS1 or LS6 block and refresh it, you'll probably be looking about the same price but have a much stronger block with Darton sleeves.
Old Aug 6, 2013 | 07:34 PM
  #560
sidewaysracin's Avatar
sidewaysracin
Originally Posted by QTB
Has anyone adapted their swap to purely run in speed density yet? I'm looking into this right now. The OEM GM pcm, for the ls2 at least, uses a blended SD/MAF system, but I'm finding the stock MAF hits it's ceiling around 500-525 g/s. Which is roughly 470HP, so anything beyond that and your clipping the MAF. Unless you replace it with a larger one whcih doesn't really make sense in my head when you can just delet it and reduce your intake restriction and simplify your tuning.
I'm running on speed density now with just the GM ecu an tuned with HP tuners. Car runs great so far. Just over 600hp on 9lbs boost. I did have to put in a 2 bar map sensor off a cobalt SS though.
