Z33Art V3.0-LS1/TH400 Swap
Old Sep 7, 2011 | 07:10 AM
  #281
bbs350z's Avatar
bbs350z
took a ride in this beast the other day... had to change my pants after. getting in with lambo doors and a cage was tough fyi.
Old Sep 7, 2011 | 04:24 PM
  #282
Quamen's Avatar
Quamen
Just a side note on swaps (if any) that use the factory 350z alternator, you must plug in the voltage regulator on your alternator or it will only put out 10-11 volts. I just jumped mine from the main positive post on the alternator to pin #4 on the side of the alternator.
Old Sep 8, 2011 | 05:01 PM
  #283
Quamen's Avatar
Quamen
Weighed the car tonight! Weighes in at a whopping 2,871lbs without me in it! This is with 10 quarts of trans fluid, 6 quarts of oil and 12 gallons of fuel in the car. The thing should absolutely fly if I can get traction.
Still open for more sponsors!
Old Sep 8, 2011 | 05:20 PM
  #284
midz350's Avatar
midz350
2,871lbs?
wow.
Old Sep 8, 2011 | 06:33 PM
  #285
Classy's Avatar
Classy
And with 450ish hp on tap with no lag! Yes drag slicks will be your friend!
Old Sep 8, 2011 | 07:52 PM
  #286
Quamen's Avatar
Quamen
Originally Posted by midz350
2,871lbs?
wow.
Yup! I could easily get the car under 2,800lbs if I bought some light weight brakes and wheels. Maybe this winter I will even switch all the fuel line over to the nylon braided hose and remove the stock Z ABS module to get some more weight out.
Old Sep 8, 2011 | 08:34 PM
  #287
Royal_T's Avatar
Royal_T
Damn 2,871lbs!?!?!?!?! Nice bro,, did you happen to weigh the car before?
Old Sep 9, 2011 | 12:39 AM
  #288
bbs350z's Avatar
bbs350z
^yup 4,326 stock lmao
Old Sep 9, 2011 | 03:08 AM
  #289
Quamen's Avatar
Quamen
No I don't get a chance. I know that the curb weight of the Z is 3,188lbs stock though.
Old Sep 9, 2011 | 04:04 AM
  #290
0jiggy0's Avatar
0jiggy0
Wow nice power to weight. Dunno if I missed, when are you dynoing it?
Old Sep 9, 2011 | 06:48 AM
  #291
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I think that's only the base model and only the earlier models.
Old Sep 9, 2011 | 06:55 AM
  #292
str8dum1's Avatar
str8dum1
on a side note, what exactly is your proposal for sponsors? Are you going to race a full season? car shows?
Old Sep 9, 2011 | 11:06 AM
  #293
Quamen's Avatar
Quamen
Season racing and some car shows here and there. Not really a big show guy but a lot of people seem to like the car.
Old Sep 9, 2011 | 11:07 AM
  #294
Quamen's Avatar
Quamen
Scheduled for 4pm today central standard time.
Old Sep 9, 2011 | 12:50 PM
  #295
bbs350z's Avatar
bbs350z
come pick me up after lol
Old Sep 9, 2011 | 05:00 PM
  #296
Quamen's Avatar
Quamen
It didn't go well so far. I am either having problems with the tuning because of the slow flame front with E85 or I am having some weird timing issues. Going to spend some time doing some more research and then head back to the dyno. I may end up switching to 105 ocatane gasoline that a local gas station sells.
Old Sep 10, 2011 | 08:49 AM
  #297
Cass007's Avatar
Cass007
Sorry to hear that, please keep us posted. Maybe try and check in with Vas, he is running an E85 tune.
Old Sep 10, 2011 | 09:59 AM
  #298
binder's Avatar
binder
vas's car is actually running? last i heard he was still doing wiring stuff about 2 weeks ago.
Old Sep 12, 2011 | 09:14 AM
  #299
Royal_T's Avatar
Royal_T
I really like this look and think I might do the same.. Did you just use one of the gauge mounting bracket pedestal to mount up?
Old Sep 12, 2011 | 09:17 AM
  #300
Quamen's Avatar
Quamen
Come on T... You know me...
It is a custom mount that I cut myself out of billet aluminum. It is very light weight and installed perfectly!
