Z33Art V3.0-LS1/TH400 Swap
Old Aug 14, 2011 | 09:37 AM
  #241
Classy's Avatar
Classy
So much different than a VQ
Old Aug 15, 2011 | 08:16 PM
  #242
Quamen's Avatar
Quamen
Started to build the bottom end of the motor today. Started with checking the bearing clearance on the mains and starting to file the piston rings. Also installed my new Speedhut gauges.
Old Aug 16, 2011 | 12:48 AM
  #243
bbs350z's Avatar
bbs350z
yea its crazy how simple a pushrod is compared to a dohc, esp with vvt
Old Aug 23, 2011 | 07:54 PM
  #244
Quamen's Avatar
Quamen
Couple updates. Just finished making a custom crank lock to help hold the crank in place while torquing the rods and measuring bearing clearances. Also got my Circle D. torque converter with billet back plate and anti-ballooning plates rated at 700whp and nitrous! Also a better picture of the pistons.
If anyone is interested in the crank lock, I made three more of them and would sell them for cheap to help out anyone building their LS motor for their swap!
Old Aug 24, 2011 | 12:00 PM
  #245
Royal_T's Avatar
Royal_T
This is soooooo freakn awesome.. This will help me out when I do my stroker engine.. Thanks.. Love that custom crank lock, you should sell those..
Old Aug 24, 2011 | 12:48 PM
  #246
Quamen's Avatar
Quamen
I was thinking about making twenty or so of them and selling them. They would be fairly cheap too, especially when compared to an $85 flywheel lock.
Old Aug 24, 2011 | 06:39 PM
  #247
Cass007's Avatar
Cass007
Looking good
Old Aug 25, 2011 | 08:37 PM
  #248
Quamen's Avatar
Quamen
Got the bottom end assembled!
Old Aug 26, 2011 | 10:16 PM
  #249
andz33's Avatar
andz33
Arp rod bolts or katech?
Old Aug 26, 2011 | 11:02 PM
  #250
Quamen's Avatar
Quamen
Originally Posted by andz33
arp rod bolts or katech?
oem gm.
Old Aug 26, 2011 | 11:03 PM
  #251
Quamen's Avatar
Quamen
I posted a huge update on my "Z33Art" Facebook page. To tired to post pictures on here though. Tomorrow I will post them though.
I will throw the forum one bone though....
Old Aug 27, 2011 | 12:01 AM
  #252
KingBaby's Avatar
KingBaby
Hardest Setting
more kind sir
Old Aug 27, 2011 | 06:24 AM
  #253
Quamen's Avatar
Quamen
Hand ported oil pump for higher flow. Also has a .050" shim in it to increase oil pressure a couple psi.
Windage tray and pickup tube installed. The stroker crank did require the use of washers on the windage tray to clear the rod bolts.
GM MLS head gasket and lifters/lifter trays installed.
Oil pan installed and ready to go!
Almost there!
I do have pictures of installing the cam that I will post later. Cam installation went well. I also degreed the cam to verify that it was set correctly and that the manufacture sent me the cam with the specs that I wanted. All that is left is installation of the final damper bolt (already did the 240ftlb's with the old bolt) and installing the push rods and rockers. Then there is just some small things here and there to pull it all together to be put in!
Old Aug 28, 2011 | 06:47 PM
  #254
Quamen's Avatar
Quamen
So I was measuring my pushrod length on yesterday and discovered that a number of my hydraulic lifters went bad. With that in mind I had to remove the heads and install brand new lifters. All went well and it just so happens that the lifters I purchased from Texas Speed were the exact correct length that I needed!
From there I busted a$$ and got everything put together and the motor/transmission/torque conveter/driveshaft put back in the car! Hoping to start the car this upcoming weekend!
Old Aug 29, 2011 | 07:19 AM
  #255
Cass007's Avatar
Cass007
You are making quick work of this project
Old Aug 29, 2011 | 08:31 AM
  #256
Quamen's Avatar
Quamen
For sure! My car is so ungodly easy to work on now and I know the entire car inside and out. I am going to really burn the candle at both ends this week to get everything put together just perfect. Should have more updates tonight some time.
Old Aug 31, 2011 | 08:23 PM
  #257
Quamen's Avatar
Quamen
Gauges are finally mounted and operational... although the oil pressure gauge is loose and twisted right now... ;-)
It is hard to tell, but I made an ultra slim billet tachometer mount to mount the tach to the steering column. In the pictures it somewhat looks like the tach is mounted to the dash, but I assure you it is not. Everything is turning out to be quite clean!
Old Sep 1, 2011 | 06:04 PM
  #258
Royal_T's Avatar
Royal_T
Every thing looks so damn good...
Old Sep 2, 2011 | 11:34 AM
  #259
bbs350z's Avatar
bbs350z
Originally Posted by Quamen
Twin Walbro 255 external fuel pumps to fuel the beast!
link to these components??
Old Sep 2, 2011 | 12:31 PM
  #260
Royal_T's Avatar
Royal_T
^^+100
