Z33Art V3.0-LS1/TH400 Swap
Old Dec 20, 2010 | 04:20 PM
  #141
Quamen's Avatar
Quamen
Originally Posted by The Fallen
Yeah, I hear some kids got one with a turbo in it or something??
Yeah, but I hear he's slow....
Old Dec 21, 2010 | 11:57 PM
  #142
eltness350's Avatar
eltness350
The Untouchable
Bwahahahahahahahaha
Old Dec 22, 2010 | 01:38 PM
  #143
Quamen's Avatar
Quamen
About 75% done stripping the sound deadener out of the interior. I have a couple spots on the tunnel and behind the dash to finish and then it is all out. Still working on removing all the glue though. Speaker enclosure should be cut out by next week and all all the glue removed. Then it is on to touching everything up with the sander.
For now I am making a "mid-brace" to help maintain the strength of middle of the car once I cut the speaker enclosure out. I made the brackets yesterday and am picking up the tubing in the morning. Hope to have the mid brace done tomorrow. Also picking up the material for my solid differential and subframe bushings in the morning.
Old Dec 22, 2010 | 03:03 PM
  #144
str8dum1's Avatar
str8dum1
i was just thinking at least put the dash bar in since the dash is already apart. You can always tie it in later. disassembling that looks like a PITA to do more than once.
Originally Posted by Quamen
I have not been spending time keeping track of the weight. Just been to busy to really care. I have removed two 42 gallon leaf bags of extra crap though not including interior trim and large pieces like the spare.
I really want to put a cage in but I think I am going to wait until after I go to the track a couple times. I want to see what starts to break so I know how much money I need to keep investing to go faster. At that point I will truely determine what specs I want to build my cage to.
I am quite sure there may be a four link and a Ford 9" going in after next season. Either way, I should be able to run low 10's before I hit 135mph.
Old Dec 22, 2010 | 11:37 PM
  #145
Havok_RLS2's Avatar
Havok_RLS2
Yeah, I heard that too.
Old Dec 22, 2010 | 11:41 PM
  #146
Havok_RLS2's Avatar
Havok_RLS2
This car makes me nervous....lol I have to make sure I make enough power to insure my top spot lol
You can have that top spot. I'd rather live. LOL
Old Dec 23, 2010 | 01:43 PM
  #147
Quamen's Avatar
Quamen
Here is my temporary mid-brace for when I cut out the speaker enclosure. Eventually a cage will be in once I have a better understanding of how deep I want to go racing. Flanges are waterjet cut 1/4" plate and the tube is .083 wall 1.5" diameter tubing.
Old Dec 26, 2010 | 08:01 AM
  #148
Quamen's Avatar
Quamen
Old Dec 26, 2010 | 03:18 PM
  #149
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Are those the Prostars? Size and weight?
Old Dec 26, 2010 | 03:55 PM
  #150
Quamen's Avatar
Quamen
Summit Warrior R/T's. 15x8
Put them on the scale and they are 17.9lbs/wheel.
Old Dec 26, 2010 | 05:35 PM
  #151
3hree5ive0ero
Retired Admin
What are you doing for the fronts?
Old Dec 26, 2010 | 07:31 PM
  #152
Quamen's Avatar
Quamen
Same wheels but 15x4.
Old Dec 27, 2010 | 04:49 AM
  #153
mw9's Avatar
mw9
awesome job,
in for pics and updates
Old Dec 28, 2010 | 08:09 PM
  #154
bbs350z's Avatar
bbs350z
saw this again last night. makes me le jealous. contemplating selling the built motor and twins to fund this. ****.
Old Dec 29, 2010 | 05:19 AM
  #155
bigcloud's Avatar
bigcloud
Do it!! I would like to see a built TT guy switch over to the dark side as well. Maybe you could be one of the firsts to put a roots blower on the LS1/2 in the Z!!! That would be epic!! There is enough room to fit one!! Ask Quamen!!
Old Dec 29, 2010 | 06:51 AM
  #156
Quamen's Avatar
Quamen
There is definetly enough room for a big blower. Need to dowel pin the crank though since the crank pulley is just a press fit and isn't keyed.
Old Dec 29, 2010 | 10:32 AM
  #157
str8dum1's Avatar
str8dum1
is it typical to run a 10.5 slick on a 8" rim or a 10". Jegs sells both in the appropriate backspace, but only the 8" in the design I prefer.
Old Dec 29, 2010 | 10:35 AM
  #158
03threefiftyz's Avatar
03threefiftyz
It's pretty common. A 275mm (10.8") on an 8" is very common actually.
Old Dec 29, 2010 | 11:08 AM
  #159
3hree5ive0ero
Retired Admin
+1 The slicks' widths that are advertised is not the tread width that actually touches the ground, so "oversizing" is common practice. I believe the widths that are advertised are the width of the tires at their widest (at the bulge).
Personally, 10.5" wide slicks are where I'd draw the line with 8" wide wheels, though.
Old Dec 29, 2010 | 03:49 PM
  #160
Quamen's Avatar
Quamen
10 is acceptable depending on the brand. I will be running M&H Racemaster slicks. Going with 26x10x15.
