Idle RPM too High; Tried Everything
Old Oct 16, 2010 | 09:45 AM
stud_daddy's Avatar
stud_daddy
Default Idle RPM too High; Tried Everything
Got my car serviced, changed the battery. Felt that the idle RPM was a little too high (>1,000). Went back and the mechanic used the Launch diagnostic computer to adjust the RPM but somehow it can't be adjusted....like its stuck and does not allow adjustment. I never had this problem. The mechanic had another 350Z there and proved to me there was nothing wrong with his computer because he could adjust the other 350Z's RPM without issues but not mine.
Cleaned the throttle body, cleaned MAF, reset the ECU, etc. etc. but nothing works.
The car seems to be running fine otherwise.
Suspicion # 1: faulty throttle body.
Any ideas?
Old Oct 16, 2010 | 11:46 AM
How long ago was the battery installed?
Old Oct 16, 2010 | 12:16 PM
stud_daddy's Avatar
stud_daddy
About 1 month.
Old Oct 16, 2010 | 02:02 PM
Originally Posted by stud_daddy
About 1 month.
Disconnecting the battery may alter the idle, but it is generally "back to normal" in a couple of days. Sorry but I have no idea what is happening with your idle.
Old Oct 16, 2010 | 09:28 PM
amr_electron's Avatar
amr_electron
First check for any error codes if you didn't. Check the MAF, unplugged or bad MAF wiring will cause high idle . You may also be having a vacuum leak somewhere specially if you have a spacer.
Old Oct 16, 2010 | 09:47 PM
dcains's Avatar
dcains
I'd look for air leaks.
Old Oct 17, 2010 | 12:25 AM
stud_daddy's Avatar
stud_daddy
Thanks for the feedback. It could very well be an air leak. I have a plenum spacer installed, and recently had the head gasket changed. Could all be contributing factors.
Old Oct 17, 2010 | 07:30 AM
rcdash's Avatar
rcdash
What year is your car and what year is the 350z that your mechanic could adjust? Only very early models can be adjusted with generic scan tools (or UpRev's Cipher). A reflash can adjust any year.
That said, your issue is probably a vacuum leak, likely near the oil filler cap.
Old Oct 17, 2010 | 10:43 AM
stud_daddy's Avatar
stud_daddy
Mine is a 2004 Japan import. The one he could adjust was a 2003, also Japan import.
Old Oct 17, 2010 | 10:59 AM
350ZTheStandard's Avatar
350ZTheStandard
SO was the problem a vacuum leak??
Old Oct 18, 2010 | 06:36 AM
stud_daddy's Avatar
stud_daddy
Don't know yet. Will find out tomorrow when I go to the workshop. Will keep you posted.
Old Oct 18, 2010 | 01:54 PM
zerosec's Avatar
zerosec
had the same problem once , we tried everything and still idle was high... 1 month after i installed the Cosworth intake manifold and iddle was back to normal.
there's a leak somewhere try to figure it out by removing the spacer and turn on the car anc see if the iddle goes back to normal..
liqalu04
Jan 2, 2022 12:58 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
