Q? what fuses to pull that will allow the engine over WITHOUT starting it?
Old Oct 17, 2010 | 06:51 AM
laze1's Avatar
laze1
Default Q? what fuses to pull that will allow the engine to turn over WITHOUT starting it?
After doing a bunch work to replace my existing Setrab home-brewed engine oil cooler, and in the process drained all the oil from the lines and cooler...
Now I want to turn the engine over a few times to get some oil into the lines without starting the Engine and having it run dry.
Note: I have filled the new oil Cooler with oil, but don't have a good way to fill the hoses and remove all the air...except for having the engine oil pump push so oil thru the system.
Q?: What fuses can I pull that will allow only the starter to turn the motor over, bu NOT provide Spark or Fuel to the engine???
BTW: Looking at FSM now for info...
Old Oct 17, 2010 | 06:59 AM
KornerCarver's Avatar
KornerCarver
You could probably pull the spark plug wires.
Old Oct 17, 2010 | 07:08 AM
laze1's Avatar
laze1
I don't think the Ignition System would like that
Old Oct 17, 2010 | 07:12 AM
Italianjoe1's Avatar
Italianjoe1
Injector, ignition (spark) and fuel pump fuses are the best bet. Don't need the fuel pump one as long as there is one for the injectors, but i'm not 100% sure on how the Z is setup. Can also pull the clips off all the injectors and coil packs, but on these cars they aren't easy to reach.
Old Oct 17, 2010 | 07:16 AM
jmahad01's Avatar
jmahad01
Yea. Just pull the fuel pump fuse.
Old Oct 17, 2010 | 07:19 AM
laze1's Avatar
laze1
Anybody know what the Fuel pump and ECU fuses are?
Old Oct 17, 2010 | 07:26 AM
Russ@Z1's Avatar
Russ@Z1
https://my350z.com/forum/engine-and-...pump-fuse.html
btw, you might want to update that user title.
Old Oct 17, 2010 | 07:48 AM
AJCaron12's Avatar
AJCaron12
Fuel pump relay or fuse.
Old Oct 17, 2010 | 07:56 AM
glenns280's Avatar
glenns280
Old Oct 17, 2010 | 07:57 AM
Russ@Z1's Avatar
Russ@Z1
you can pull the relay
Old Oct 17, 2010 | 08:26 AM
midz350's Avatar
midz350
If you pull the fuel pump fuse the car may start for a few seconds and that may freak you out, I know I did
Old Oct 17, 2010 | 08:27 AM
laze1's Avatar
laze1
Fixed!
thnx for the link!
F
Old Oct 17, 2010 | 08:28 AM
laze1's Avatar
laze1
That is why I want to kill the fuel pump AND Spark.
Old Oct 17, 2010 | 09:04 AM
midz350's Avatar
midz350
When this fuse went out on me, the car will turn over but it wont start.
It has something to do with the injectors.
Old Oct 17, 2010 | 11:46 AM
terrasmak's Avatar
I feel dummer for reading that.
LOL, i know its dumber.
Old Oct 17, 2010 | 12:24 PM
Italianjoe1
Exactly, pull the injection fuse, it won't start.
Old Oct 17, 2010 | 12:35 PM
laze1's Avatar
laze1
This worked...pulled the Ignition and Fuel pump relays, engine turned over but didn't start....turned the engine over till I got some pressure (careful to not overheat the starter) ...the reinstalled the relays, then started car, then changed the oil...service complete!!!
Old Oct 17, 2010 | 12:36 PM
laze1's Avatar
laze1
All....thnx for the help!
Old Oct 17, 2010 | 07:54 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
liqalu04
Jan 2, 2022 12:58 PM
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
