Flywheel + Clutch Replacement for $2700+??!! HELP!
Old Nov 12, 2010 | 07:50 PM
o2intake's Avatar
o2intake
Default Flywheel + Clutch Replacement for $2700+??!! HELP!
So my clutch just stays depressed and doesn't come up.. I thought it would be either the clutch line, or master/slave cylinder issue but nissan dealership is saying its the flywheel and clutch.
They want $2700 for parts and labor saying parts alone will be $1100+.
Calls to two different pep boys..
1st said it would cost about $1000 for everything (said cheaper if they can just re-surface the flywheel)
2nd said it would cost $550 for labor plus part cost
I know the dealership is a ripoff for repairs but should the discrepancy be this big? Would it be better to just have pep boys do it or is there something better about the dealership?
I'm in socal (OC area) and if anyone got their flywheel + clutch replaced at a local shop for a good price. Could you let me know.. I rather support them than the dealership.
THANKS!
Old Nov 12, 2010 | 07:52 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
why not just upgrade and come out cheaper?
Old Nov 12, 2010 | 08:00 PM
o2intake's Avatar
o2intake
Yeah, I've been leaning on just towing my car from the dealership to pepboys and have them install some aftermarket parts.. jwt ftw?
Old Nov 12, 2010 | 08:02 PM
POWUH's Avatar
POWUH
^^ 1+ precision z has the jwt combo for 1,350 flywheel + clutch + installation I would go that route.
Old Nov 12, 2010 | 08:16 PM
2004Black350z
Exhaust Whore
Pepboys? R u fcking kidding me? lol. i hope so. Go to a actual reputable shop.
Old Nov 12, 2010 | 08:47 PM
POWUH's Avatar
POWUH
^^ lol seriously , next thread title will be " help pep boys ruined my car " haha.
Old Nov 12, 2010 | 09:01 PM
blue350zed's Avatar
blue350zed
Definitely time for an upgrade ( Exedy is my weapon of choice ), and time to find a better shop. Gotta be a ton of 'em over there in SoCal???
Old Nov 12, 2010 | 11:37 PM
midz350's Avatar
midz350
OP, is you car 07-08? then its not the clutch, its the CSC. (when that happen, did you noticed oil under the car?)
Read here:
https://my350z.com/forum/vq35hr/3281...-cylinder.html
solution here:
https://my350z.com/forum/drivetrain/...or-hr-vhr.html
Old Nov 13, 2010 | 12:32 AM
o2intake's Avatar
o2intake
Default socal help !
mines an 08 =( so no go. and no on pepboys it seems... wheres these reputable shops... socal people help me out please !!!
Old Nov 13, 2010 | 12:40 AM
POWUH's Avatar
POWUH
precision z located in canoga park ca , google it
Old Nov 13, 2010 | 06:47 AM
Old Nov 13, 2010 | 09:51 AM
bardabe's Avatar
bardabe
if you are in the Lower Socal Area, I'm in the Inland empire and can take care of you no problem. I am an Authorized SZ Dealer and Installer. I can give you a killer deal on our Flywheel, Clutch and CSC Combo.
Old Nov 13, 2010 | 10:30 AM
Sooner350's Avatar
Sooner350
I hope DavidV is younger than 18. If not it looks like he's a pederass. Hide yo kids, hide yo wife.
Sorry I'm feeling like a jackass today.
OP. I would take your car to bardabe or another reputable shop like others have suggested. The Specialty Z setup looks pretty good, and will most likely be what I purchase some time next year.
Old Nov 13, 2010 | 07:26 PM
winchman's Avatar
winchman
Are you already out of the warranty on an '08?
If the clutch was working OK before the pedal stuck at the floor, I'd suspect it's just the CSC. Did they show you the parts they say need to be replaced, or are they making a diagnosis based on what they'd like to sell you?
Old Nov 13, 2010 | 09:26 PM
o2intake's Avatar
o2intake
Yeah, I'm at 40,000 daily driver..
The clutch was fine, then suddenly it got wouldn't come up all the way after I changed gears.. it would stay right above the "sweet spot". Then after a couple more gear changes it stayed fully depressed.
The dealership did a diagnostic on the car and the service advisor called me and said it wasn't a cylinder issue but a flywheel and clutch. =[
I didn't abuse this car and I don't understand how the flywheel could go out at just 40k.. sigh..
Old Nov 13, 2010 | 09:30 PM
TheFarmer's Avatar
TheFarmer
Your flywheel didn't let go...you will have bigger issues if it did. I would get a second opinion from a shop that deals with Z's, like Precision Z. It could just be a slave cylinder.
Old Nov 15, 2010 | 01:23 AM
winchman's Avatar
winchman
All the things that might cause the symptoms you describe are inside the bell housing. A blown slave would be obvious because the oil would be leaking out, but it could be the piston is just stuck in the slave cylinder.
It's remotely possible the some part of the pressure plate has broken, but that's VERY unlikely without serious abuse.
A real diagnosis would require removing the transmission. Without doing that, I'd say they're just guessing.
Old Nov 17, 2010 | 09:39 AM
pntfrk69's Avatar
pntfrk69
have you tried messing with the clutch fork? cause if the pivot ball broke you could have similar problems and they are only a 5 dollar part
Old Nov 17, 2010 | 11:42 AM
winchman's Avatar
winchman
But don't you still have to remove the transmission to fix it?
Oops. I forgot the OP has a HR.
Old Nov 17, 2010 | 01:59 PM
bardabe's Avatar
bardabe
07 / 08 don't have a clutch fork, we have a Concentric Slave Cylinder.
I'm telling you man. I can give you a sick deal on the SZ Clutch flywheel and CSC Combo.
