stuck 5th & 6th Gear
Old Nov 19, 2003 | 07:26 PM
dchi_t's Avatar
dchi_t
Default stuck 5th & 6th Gear
2nd tranny in the car today, took it on the local - everything was fine. then once on the freeway, i took it up a notch, then uh o! 5th gear wont engage, i couldnt even force it in, what can be a prob? syncrhos exploded w/out my knowledge? and needless to even mention 6th gear, i couldnt even find my 6th gear. wtf right?!?! im gonna call the service guy first thing tomorrow when i get a chance. do u guys think the shifter was installed incorrectly? cuz when i shake the shifter left and right the freeplay from neutral middle to left is more than neutral middle to right. feels like something gets in the way of the shifter when i try to push it to the right? so..answers anyone?!?! thx
dean
Old Nov 19, 2003 | 07:28 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
What dealer did you go to? Monterey park is about 15 minutes from Performance Nissan and I don't think we had any tranny jobs in today at all.
If they dont take care of you bring it by us. We will.
Good luck!
Old Nov 19, 2003 | 08:00 PM
dollar99's Avatar
dollar99
you need to adjust your shifter guide plate. You can do that yourself, look at the rogue engineering short shifter instructions, theres a section on how to adjust the guide plate. Very easy.
Old Nov 19, 2003 | 11:11 PM
dchi_t's Avatar
dchi_t
hahah..jason, as a matter of fact, i got it done at ur place, i bought my car at ur place too...and i trust u guys with the worksmenship u provide, but this is horrible, i was forced to drive on the freeway on 4th gear all the way home, i will try to play around w/ the guide plate a bit tomorrow afterwork, and if that doesnt do the trick i'll let u guys handle it ok? thx
Old Nov 19, 2003 | 11:15 PM
dchi_t's Avatar
dchi_t
some thoughts...at first i was afraid the mechanice had forgot to put tranny fluid in there, but i didnt think so, cuz 1stG-4thG is totally fine, just 5th and 6th is crazy stiff and it feels like im really hurtin the gears, but actually i have to push the **** down how u would have to get into reverse to get into 5th and 6th smoothly, so 60% its the guide place installed crooket? i will check tomorrow.
Old Nov 19, 2003 | 11:49 PM
ether's Avatar
ether
from what you describe it sounds like its definitely the guide plate.. the shifter mechanism has a small tab that prevents it moving further to the right unless you push the shifter down, that makes it an extra step for engaging reverse. it seems like your guide plate is just too far to the left requiring you to push down to have access to both 5th and 6th.. its a simple adjustment .. look at the instruction for the rouge shifter.. on page 8 it explains how to adjust it.. if you take in to get it fixed, needless to say, it would be safest to not even try getting into 6th
http://www.rogueengineering.com/pdf/...er_install.pdf
Old Nov 20, 2003 | 07:53 AM
dwnshift's Avatar
dwnshift
Another problem area is the little plastic cup that the shifter sits in. There is a rubber ring around the top of it. We have had to replac this cup often. We had this same problem at Daytona. If we got it into 5th we could get 6th.
Old Nov 20, 2003 | 02:40 PM
dchi_t's Avatar
dchi_t
wow..thx for all ur ppl, this forum really is a life saver, i adjusted the guiding place and i finally found my 6th gear! hahah...good xhit! iight had a little trouble gettin the **** off but a little elbow grease and it came off w/ a fight. hope i didnt hurt anything, ok thx again guys
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Beater350z
Sep 9, 2015 03:36 PM
