UR Pulley install on 5AT - tip
Old Nov 19, 2003 | 07:52 PM
zzzya's Avatar
zzzya
Default UR Pulley install on 5AT - tip
I installed the UR pulley set today and wanted to share a bit of information that I was not able to find on the site in my searches. I have the 5AT and was not quite sure of the best way to stop the crank pulley from spinning while removing and then later when tightening. I had heard some were using chain wrenches and such. Well, I found a small plate that is held on by two bolts located on the driver's side of the transmission. This plate when removed will give you very quick and easy access to the flywheel. You can then insert a crowbar into the opening to prevent the flywheel from turning thus allowing for the crank pulley bolt to be removed and/or tightened. I was able to do this by myself and once I found this opening it took 30 minutes to install the pulley.
Old Nov 19, 2003 | 07:54 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
So AT guys can use a lightened flywheel too??
Notice anything with the pullies on? I was told it's barely noticeable
Old Nov 19, 2003 | 08:01 PM
zzzya's Avatar
zzzya
UR claims that you have to give the ECU time to adjust before max gains. I went for a spin and my initial thoughts are an improvement in torque right around 2.5-3k. The car seems to respond to the accelerator better, a bit snappier.
Old Nov 19, 2003 | 08:02 PM
shinz's Avatar
shinz
I too have a 5at and was thinking about getting the UR pulleys as my first mod, post a short review if you can. thanks.
Edit: oops sorry, didnt see your last post, forget what i said =)
havabooz's Avatar
havabooz
supposedly AT's dont have a flywheel...someone please clarify
Old Nov 19, 2003 | 08:05 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
That's what I thought too...
Old Nov 19, 2003 | 08:10 PM
zzzya's Avatar
zzzya
The engine flywheel is located on the crankshaft which is what the starter lines up with to turn the engine over for starting. The flywheel is not part of the transmission. An Auto goes flywheel, torque converter, then transmission.
Old Nov 19, 2003 | 08:22 PM
zzzya's Avatar
zzzya
Just so you understand that the flywheel on an automatic serves a different purpose than a flywheel on a manual. The flywheel on an automatic is usually much lighter to start with than on a manual transmission setup because the torque converter on an auto setup helps to smooth out the power pulses from the engine not the flywheel.
Old Nov 19, 2003 | 08:51 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
I learned something new today! Thanks zzzya!
Old Nov 20, 2003 | 04:27 AM
Zrated's Avatar
Zrated
The AT has what is called a flexplate not a flywheel.
Old Nov 20, 2003 | 06:39 AM
Z4ToddB's Avatar
Z4ToddB
Damn! Wish I would've known this trick 2 weeks ago when I struggled to get mine on! As far as how it feels (don't flame me I didn't do a dyno) intially, I was a little disappointed (only because it was 200 bucks)as it didn't feel like it made a whole lot of difference, although it did seem like it moved the tach needle a little quicker toward redline. Fast forward 2 weeks later after an ECU reset...Now, it DEFINETLY feels quicker! Might just be the "placebo effect", but it sure seems like it is. Dyno results I've seen in other threads say 2-5 HP, but it sure seems like more. Anyway, I'm glad I did the mod and am sure it made a difference- Just my .02 on the subject-
Old Nov 20, 2003 | 06:57 AM
Ultimateone's Avatar
Ultimateone
zzzya did you unplug the battery during install for the ECU reset?
Old Nov 20, 2003 | 07:19 AM
Z4ToddB's Avatar
Z4ToddB
Not sure if this was supposed to be to me, but no I didn't, I did the whole turn the key on, wait 3 secs, pump the gas peddle wait, etc I saw in a different thread about "resetting the ECU".
Here's the link-
http://www.technosquareinc.com/350reset.htm
TB
Old Nov 20, 2003 | 08:53 AM
Ultimateone
Thanks Todd
Old Nov 20, 2003 | 09:06 AM
Mr Twisted's Avatar
Mr Twisted
Just had the pullies and TS ECU put in and dynoed for a few days now. Sanes peppyer now and the Dyno Numbers are +8 whp for the combo on a 5AT. I'm now at 252.6
Old Nov 20, 2003 | 02:41 PM
zzzya's Avatar
zzzya
Some call it a flexplate and others call it the flywheel, really goes hand in hand.
No I did not reset the ECU yet and planned on looking into that some more tonight so thank you Todd for the link.
Old Nov 20, 2003 | 02:43 PM
Z4ToddB's Avatar
Z4ToddB
Anytime! Your both welcome-
Old Nov 20, 2003 | 02:46 PM
Z4ToddB's Avatar
Z4ToddB
Oh, one thing I forgot...I had to attempt that procedure like 5 times before it worked. There was a post in here somewhere that talked about how critical it is you follow it exactly (use a stop watch or your watch's second hand) If you're not right on the times, it won't work. So just expect it and be patient, you'll get it eventually...it does work!
Todd
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Nov 9, 2015 11:10 AM
nanotech
Oct 2, 2015 05:02 AM
