oil consumption...yeah again
Old Dec 7, 2010 | 07:05 PM
Tweakin's Avatar
Tweakin
Default oil consumption...yeah again
hey guys,
do we know what actually causes the oil consumption issues that plague these cars? i found the TSB thread but i doubt i'd ever get nissan to spot me a new motor as mine's an '03 with 106k miles
my issues didnt start till around 60k and i've been consistantly burning about a quart every thousand or so miles
Old Dec 7, 2010 | 08:59 PM
106,000 miles maybe the motor is just tired. You already know you should have a compression test done.
Old Dec 7, 2010 | 10:10 PM
winchman's Avatar
winchman
Unless it's leaking out, it has to be going past the rings and/or valve stem seals.
Old Dec 8, 2010 | 08:05 AM
Tweakin's Avatar
Tweakin
no leaks, like i said been like this since 60k. i dont baby my cars but i also dont run them into the ground
i was just wondering if anyone knew what caused this
Old Dec 8, 2010 | 12:05 PM
winchman's Avatar
winchman
See post #15 here: https://my350z.com/forum/engine-and-...iscussion.html
"They think oil is being pulled down the valve guides by high vacuum b/c the variable valve timing is leaving the intake open too long."
I can't attest to the accuracy of the info, so judge for yourself.
Old Dec 8, 2010 | 02:00 PM
...umm lets see. Oil someplace where it should not be. Like in the combustion chamber.
Old Dec 8, 2010 | 02:05 PM
BonesZ33's Avatar
BonesZ33
sell and buy a non rev up
Old Dec 8, 2010 | 03:12 PM
KornerCarver's Avatar
KornerCarver
Any car will eventually start burning oil. That is just a fact of life. After 106K, I can't imagine complaining to Nissan about the problem. A quart of oil every thousand miles after 106K is not unreasonable. Just add a quart every thousand miles and don't worry about it.
Old Dec 8, 2010 | 04:08 PM
rwd > fwd's Avatar
rwd > fwd
dont feel bad i have an 03 with about 48k on it and it uses oil just about as bad as yours, fortunately i bought an oil pan with increased capacity. winchman is probably right about the consumption coming from the valve stem seals since i have performed compression tests on my engine several times and have had good even compression from all 6 cylinders. personally the only other thing that i can think of would be crankcase ventilation. if you have ever had the upper plenum off of the intake, and removed the cover that is in the middle of intake you will see that each intake runner has its own port where crankcase gasses (or in our case oil) is going into the intake. i have tried a catchcan in line with the crankcase ventilation hose and have been able to figure out where some of the oil is going. i ordered some viton valve stem seals from z1 but havent been able to get enough time to put them in yet. plus i have been debating some other mods while i have it torn apart. either way i feel your pain man.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
