How quick with normal bolt ons?
Old Nov 22, 2003 | 01:37 AM
Dough Boy's Avatar
Dough Boy
Default How quick with normal bolt ons?
What kind of times can you expect with the normal bolt ons such as intake/exhaust/headers...
Talking like mid 13's?
Old Nov 22, 2003 | 04:59 AM
350Z_Redline's Avatar
350Z_Redline
Default Re: How quick with normal bolt ons?
See my sig below. With some stickier tires I'd be pretty close to high 12's. I believe mid 12's are possible N/A without opening up the motor. I'll be adding the crawford plenum, TS ECU, 350evo Throttle Body, JWT flywheel and clutch within the next month. That setup should get me solidly into the high 12's if I can get traction. Next yr I'll be adding the 350evo gears, lighter wheels and sticker tires and I should be in the mid 12's.
Old Nov 22, 2003 | 11:25 AM
ElvishasaZ's Avatar
ElvishasaZ
concur..
plus changing the final drive as long as you get traction/hookup you should have a go at hitting 12's
Old Nov 22, 2003 | 11:48 AM
FLY BY Z's Avatar
FLY BY Z
If you change the final drive you will def have to shift to fifth. That's not a plus. I am doing 6100 RPM in 4th through the lights. 3 shifts is enough for me.
Old Nov 22, 2003 | 08:45 PM
Strife350z's Avatar
Strife350z
350z_redline: have you dyno'd your car? nice list of mods you got there... and an even better timeslip congrats...
Old Nov 22, 2003 | 09:31 PM
350Z_Redline
Thanks! No dyno yet. I'll dyno after the plenum, TB and ECU go in. I'm not really concerned about HP numbers, I'll be dynoing just to verify that TS worked their magic on my A/F ratio
Old Nov 23, 2003 | 08:47 AM
time4aspliff's Avatar
time4aspliff
Sub 14 second times are very realistic and getting into the twelves (n/a) would be sooo sweet! The bone stock Track model that Car & Driver tested last year ran the quarter in 13.8.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sales@czp
Sep 23, 2019 03:30 PM
codek
Sep 28, 2015 03:03 AM
