can you get higher rear gears? ~3.08?
Old Jan 8, 2011 | 06:51 AM
parish8's Avatar
parish8
Default can you get higher rear gears? ~3.08?
seems like the stock gear is in the 3.4-3.5 range? i see lots of you going to a 4.0 range.
can you get gears or is there a dif from some other car like a g35 that might have higher(2.92, 3.08...) gears?
Old Jan 8, 2011 | 07:07 AM
JasonZ-YA's Avatar
JasonZ-YA
available are:
3.3 found in automatic 350z diff, i believe certain G35 too.
3.5 MT 350z and G35diff
3.69 G35 sedan 2007-2008 MT diff
3.9 central 20 gear set - not sure if still available
4.08 Nissan frontier gear set.
Im sure i missed some dates, and model specs, but ya...thats about it that i know of..
I know some auto G35's, i think sedans only have 3 bolt pinion flanges, the 350z needs the 4 bolt pinion to driveshaft pinion/companion flange.
Why would you want higher?? FI car with high HP??
-J
Old Jan 8, 2011 | 07:47 AM
parish8's Avatar
parish8
plan is a boosted ls motor with a 4l80e. i want to stick with the stock style rear suspension as long as i can do to the classes i want to race in.
if a 3.3 from an auto is the best i can do then that is what i will get. thanks!
Old Jan 8, 2011 | 08:08 AM
JasonZ-YA's Avatar
JasonZ-YA
Old Jan 10, 2011 | 07:34 PM
Steve-O Z33's Avatar
Steve-O Z33
If you're doing all that, why not throw a Ford 9" out back? There are nearly endless options for gearing with those.
Old Jan 12, 2011 | 12:38 PM
rocks's Avatar
rocks
Armada has 2.92 gears not sure how much it would take to adapt a r230 diff in the 350z. You could use the 3.36 auto diff with taller tires.
sherm
Apr 11, 2020 05:21 PM
